Copper flute?
I live in estonia. No bamboos here.
So I was thinking to use copper tube.
I find this http://www.aflauta.com.br/hist/bamboo.pdf
Problem is inside diameter and wall thickness.
If i'm getting it right for every key is right inside diameter and lenght
I can buy straight copper tubes/pipes:
15mm(outside diameter) x 1,05mm(Wall thickness)
1,05x2=2.1mm
15-2.1=12.9mm(inside diameter)
18 x 1,0
1,0x2=2
18-2=16
12 x 1,0
1,0x2=2
12-2=10
10 x 0,8
2x0,8=1,6
10-1,6=8,4
Whats the best? I was thinking to use 15mm and 18mm tube
18mm for key a
15mm for key d
I ended up with 15x1,05 copper tube.
Thinking how to use this:
http://11wall-west.com/~ph_kosel/flutomat.html
If I use this measures http://www.phy.mtu.edu/~suits/pvcflute.html
I get 7.2mm for blow hole and 6mm for finger hole. My tube I.D is 12.9
Is there any flute calculator that calculates hole sizes for right key?
I am also thankful for any flute related help what helps me to make copper flute.
caitlinsdad2 years ago
This is pretty complicated, as is making pipe organ tubes
http://www.chrysalis-foundation.org/flute_tone_hol...
Maybe just make a sample one and tweak it? Good luck.
DeathSuperMario (author)  caitlinsdad2 years ago
Pipe organ tubes needs right length.
Flute needs also right size holes in it.
