Cutting through a surfboard
My house is set relatively far from the road and I'd like a large address display. I was looking to punch out the numbers [5 digits] down the center of an old surfboard, but not sure about what tools to use to get through the resin and then the foam; without shredding or splintering it. I have variable band, scroll, recip and jig saws; and a variable speed Dremel. I'd like for it to be as detailed as possible [hard edges]. I'm of course planning to illuminate it. Any suggestions, recommendations, ideas would be appreciated. Thanks in advance.
8
comments
Add Comment
http://www.tikitian.com/addy2.JPG
I hope you put up an instructable on the process, at least throw it up in a photo instructable for others to see.
It originally had the flickering candle lamps, but I put a black light in for halloween.
Had to take it down because I was painting the house and I was painting the board to match.
And I think what you meant to say was, "If it is a fiberglassed board, you might run into the "stringy" strands that will be difficult to cut.....out from the tips of your fingers and from under your nails."
Awesome. Thanks again.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
