DIY flashing shoe sensor
I've seen tons of guides on how to make my shoes light up with the guts of an old pair of light up shoes, but I dont want to go out and find an old pair.  Does anyone know what kind of sensor they use to turn on the lights and any pre existing circuits I can use?
Kiteman6 years ago
You don't need a "special sensor" - just make a battery+LED circuit, with a vibration switch in the circuit.
The switch is a coil or loop of wire with a length of piano wire through the centre, but not touching. When you step, the wire moves and touches the spring, completing the circuit and making the flash.
You can use a short piece of wire if you add a weight to the end to aid the vibration (say, a blob of hot-glue or epoxy). Have a look at the Blinky Bug project, or search for vibration sensors.
rpeet687 (author) 6 years ago
Thanks for the ideas and does anybody know what kind of capacitor I should use to get that dimming effect after I let go of the switch? BTW I'm starting off with 2 white leds (3.3v / 25 mah) and possibly a 3 or 6 volt power supply on a parrallel circuit.
robokid966 years ago
Dumpster-diving is perfect for this.
get an old kiddie lightup shoe and gut the hell out of it!
try replacing the 'jiggle' sensor with a push button right under the sole.
caitlinsdad6 years ago
Look up soft circuits for the pressure switch. Everytime you step down, the circuit is completed to light up the shoe. There are a few LED light up shoes instructables too! Good luck.
