DO YOU HAVE SOME MYTHS THAT YOU WOULD LIKE MYTHBUSTERS TO TEST
108
comments
Add Comment
| 1-100 of 108 | next » |
Step 1: Gun has been fired. (Assuming it was a pistol)
Step 2: Newton's law says the gun will go backwards as the bullet flies out.
Step 3: Wrist acts as a pivot that makes the pistol "kick up".
In the case of the M16 the stock is designed so there is no viable pivot to make the gun pivot.
To answer Skate6556's question it is more likely that the gun will kick sideways. Take note that I only said "more likely" due to the fact that I haven't shot a gun myself.
It's a solar laser okay. I know it looks weird, sorry, it's paint, I've got nothing else as a visual aid. Anyway, the weird looking egg-shaped stuff there focuses sunlight onto a mirror which then reflects the light to another mirror which combines the energy of the two collectors and sends them of to the other ship where the sailors take a dive into the abyss of shark infested waters...
I've been wanting to comment that to the Mythbusters but I don't know how, so I just told you people instead. Or maybe I should have just asked you how?
Fresnal Death Ray
I think we have digressed pretty far from the original point of this thread though. lol.
Did you spell Mythbusters "MYTHBUSTE_S" on purpose or what?
The method using Iron and Sulfiric Acid will consume the material used which lose this energy. This means to produce more Hydrogen you need more iron and sulfiric acid. These materials would then have to be liberated using electricity/energy before they can be reused. The result is that it consumes more energy then you would get after including other factors.
The bigger problem with hydrogen as a fuel is the difficulty in containing it. Hydrogen has several properties that make it difficult to store. A big one is Embrittlement. Sadly, the only way we will likely use hydrogen as a fuel source is fusion. Though it could easily be used in solar power generation as a chemical battery to store energy for use during low output times.
Right now, the most efficient method in use to produce Hydrogen in large quantities uses Fossil Fuels. See HERE
I mean every one of their explosives and most of their experiments are lethal... :P
A 1 foot long cylinder will contain some carbon nanotubes to store the megawatts of energy needed to power the thing, a cylinder that contains lots of compressed air (as much as you need), a spark gap/plug (whatever you call it), and a strong, super heat resistant ceramic that can fold up to fit in the ligthsaber (hence, the 1 foot long reason). Of course, an electromagnet.
Here's the idea: the tube will contain the mentioned parts, the ceramic tube shoots out, the ceramic will have holes, the air rushes out of the holes, the spark thing will do the work on the air making plasma, the magnet will keep the plasma from going out of control. The carbon nanotubes, thanks to its unusual electrical properties, will store enough power for all the work. The ceramic shoots out because of the rush of air. The air comes from a super compressor (kinda like a jet turbine).
If you have any questions just reply here!!!
I want them to test if it is true that if you flush all the toilets in a large building at exactly the same time, all the pipes will burst and flood it, or otherwise cause catastrophic damage.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
