Different Modes and Arduino?
Hello!
I had a question.
I want to have like 5 buttons and every time I press one button it runs a certain block of code over and over until I press another button. This way I can have different modes etc. mode 1, mode 2. . .
Can somebody help me with the code please?
Thanks
1-10 of 20Next »
robobot31122 months ago
You could possible make a principle code and use the IF statement for example-
void setup(){
enter all constants, variables and stuff here (for all the codes)
void loop(){
IF (condition button press 1){
your code
ELSE IF (condition button press 2){
your code
and so on
the only disadvantage i see is that it takes too much space, but it is possible
Nic-SMD3 months ago
Hello,
I need to make a project but my zero knowledge in programming does not allow me to go far.. For someone with the knowledge and experience may be a code for children :)
My code needs to have three different modes just to activate two relays in a different way at each mode.
Can anyone help please?? I will send a brief description of what I need.
Anshu AR Nic-SMD3 months ago
Hi,
So, let me get this straight:
You want three modes(inputs) to control two relays. Right?
I can help. Let me know a little more about the input mode. Is it a pushbutton? Also what output(Result) you want for each input.
Nic-SMD Anshu AR3 months ago
Hi,
Thanks a lot for offering to help me on that. I can send you a brief description via email if you like to take a full view off what I need.
Alright go ahead.
You can send me the details through personal message on my instructables account.
take a look at this
Alright!
Hi Anshu,
Any news? Do you think that you can figure out something of this?
Hi,
Sorry that setup turned out to be lot complicated (for me)
I can write a program to perform a simpler function.
The main obstacle is that the Arduino needs to store some data on which button was pressed earlier.
Apart from this everything is cool.
I can code for a setup that turns on or off the relays and even display the outputs and inputs on the LCD.
But, nothing that complex. Sorry! :(
First of all I am really appreciate your time.
What I have seen so far is that many use multiple void () functions or what they call them. So 3 different void(), one for each mode. And then you call the in void loop() or in a main void(). And I think a counter function to count the times that the button has pressed.
Why Arduino has to know what button has pressed earlier? I am asking because after you select and finish a mode it has to go back in the beginning and can select any mode you want, even the same as previews.
1-10 of 20Next »
