Lomography Konstructor - World's First 35mm DIY SLR
Office Warfare Book on Sale Now
List of Upcoming Contests (updated 6/6)
Spanish translations of Instructables / Instructables traducidos al Espanol
If you Need Help with your English Instructable - I'll Help Edit & Fix it Up
JULY 2013 Build Night with SUGRU
High-current, electronic sword-fighting, fancy drink pouring, and more @ Makers Local 256 Build Night!
New Instructables Books for 2013
Souped Up: Projects to Make Everything Better [Book]
Backyard Rockets Book on Sale Now
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Yes
Unless the diodes are well-matched, the characteristics in each case won't really be doubled. In cases where the diodes are really pushed to their ratings, then voltage sharing resistors need to be added.
The same approach is used when two capacitors are connected in series to increase the current capacity. Unless "sharing resistors" are added, one cap will always carry a higher burden, leading to premature failure.
The series diodes forward voltage drop would be cumulative (as you thought, guyfrom7up.)
Reference 2
I've never had cause to explore this with diodes, so I can't elaborate on their effects; but their use with caps is pretty common...
AKAIK, either diagram only makes sense if it's showing a reverse bias. The resistance values needed to 'balance' two nearly identical diodes would be very small, and likely not effect rectification (place a 5M resistor across a rectifying diode, and see if if prevents operation.)
Neither reference qualifies their use to only DC, and I believe that interpreting the diagrams only (when no distinction is drawn in the text between DC and AC) is possibly a mistake...
You're using a voltage divider circuit to "share" between the two diodes. While that may increase effective reverse voltage ratings, some reality is involved. Between differences in the diodes, even the tolerances of the resistors, you will not be doubling the rating. I sure wouldn't stick two 300V diodes together like that and expect them to handle 598V. Maybe 350V, if really pushed 400V, but not up near 600V.
(BTW, why is it with the 2nd reference there is a "W" showing up where an ohm symbol should be?)
Oh, some form of current direction alteration is implied. Those diodes are going in a real circuit somewhere. If all that was desired was blocking of current in one direction always, with a current source always going in that direction, nothing works better than an open circuit.
Diodes are cheap enough in bulk. If only one is used and it's bad (current goes straight thru) other components could get killed during a full-power test, two in series is insurance. Also reduces customer complaints, they may never know one went bad in use. Even a marginal ratings increase could mean they can use the same diode as elsewhere in the board, or a standard size in-plant, reducing inventory. Many reasons possible.
Well, we can at least agree on one point. ;-)
As for the rest, I still maintain that the reverse breakdown voltage is ~ double for two--just as the forward voltage drop for two diodes is ~ double. That's why the series diodes are added, to counter inductive and capacitative spiking.
So it's your turn to supply references...
Another usage for rectifiers with avalanche capability is putting individual diodes in series to obtain higher reverse voltage capability. The voltage normally divides in proportion to the reverse resistance of each diode. Since there could be large variation in the reverse resistance, the voltage may not divide equally across the series string of diodes. A transient of sufficient amplitude will drive the voltage across one or more diodes into the breakdown region. A typical diode will exhibit catastrophic failure when this occurs. However, avalanche type diodes will cause the voltage to divide much more evenly. Also, the avalanche diode is capable of protecting itself by handling transient energy, providing it does not exceed the energy rating of the diode. Thus, whenever diodes are connected in series to increase the voltage rating, avalanche diodes should be used.
Don't expect double the rating from two in series.
Ah! You could be seeing 2 diodes in series to drop a voltage down, cheaper than using a secondary voltage regulator.
Heh, apparently it's very rare to use them as you say, at least from a design viewpoint. Can't find them like that at Wikipedia, nor anyplace else really. A search for "increase diode voltage rating" turns up this thread on the first page.
I'll try to search more, but right now there's a lightning storm blowing so...
http://schematicheaven.com/fenderamps/fender_bassman_ac568.pdf
http://schematicheaven.com/fenderamps/pa100.pdf
http://schematicheaven.com/fenderamps/fender_bandmaster_ad1269.pdf
http://schematicheaven.com/fenderamps/showman_6g14_schem.pdf
Yeah, well theoretically, yes, as noted before. I'm still sticking with my original statement.
From here. But certainly two series diodes can be damaged by too much current. Eventually. Given enough current. As can any single diode. Or 100 diodes in series...
You're kidding, right? ;-) I'm sure we both know the difference between forward voltage drop and reverse breakdown. But the forward voltage drop is cumulative; I'm pretty sure the reverse breakdown voltage is, too...
I believe its is in a diode's operating definition that when the voltage rating is exceeded all that will do is allow the current to flow backward - this doesn't mean the diode is burn out - its just normal a operation of a diode. They will only burn out if we exceed the maximum current rating. Some people say high voltage = high amps based on ohm's law, however I doubt you are gonna be able to supply 6 million watts (600V 10 kA) - which is needed to burn out two general purpose diodes in series in a reverse biased configuration.
Why did he need one? You can find them in old microwave ovens. Was that really just a diode assembly, rectifying a high-voltage source, or part of a voltage multiplier circuit? Depending on the circuit, multiplier diodes only have to be rated for the incoming voltage or twice that. You can build a nifty high-voltage circuit with general-purpose diodes.
A Zener diode perhaps, but they're specially made for that, think there's a few others that can do that trick. But otherwise, at breakdown the diode will heat up, melt the little bit of silicon or whatever, and there goes the precise doped semiconductor regions, when it cools down what's left won't be a rectifier but will let current thru, both ways. With enough amperage the bit will vaporize, and no current will get thru.
You have "general purpose" diodes that can handle 10,000 amps? Dang, the small general purpose ones I play with might only do a few amps. Where do you get those diodes?
Two mechanisms can cause breakdown, namely avalanche multiplication and quantum mechanical tunneling of carriers through the bandgap. Neither of the two breakdown mechanisms is destructive. However heating caused by the large breakdown current and high breakdown voltage causes the diode to be destroyed unless sufficient heat sinking is provided.
http://ece-www.colorado.edu/~bart/book/book/chapter4/ch4_5.htm
So as I stated, most AC high voltage applications cannot supply a large current - which is needed, in conjunction with the high voltage, in order to heat up and destroy a diode.
Well so much for that "reference." A common 1n400x diode can only do 1A normally, resistive and inductive load, subtract 20% for capacitive load. 30A for a single stray short pulse. "High current" for a single diode is about 75A in an industrial-looking package. You can find "rectifiers," large units with many diodes, around 1000A, they're used for electroplating, large items or large batches I'd assume. Heck, I doubt you could even find a wire that can handle 10kA, for copper wire to handle only 300A requires a 4/0 (0000) stranded cable with 0.46" diameter, that's 0.166 square inches cross section, 10,000A would need 5.54 sq in, about 2.7" diameter! And that's just the copper, with insulation it'd be about 3 inches across.
Now, I don't know about you, but if I came across a single diode that needed a 3" copper cable to hook up to it, I sure wouldn't consider it "general purpose." Might not be one of the "special" types, but it sure wouldn't be used by a DIY-er for HV, let alone anything else.
You quoted:
For the common 1N4001 the top temp of its operating range is 175o C, beyond that it goes real bad real fast. They're in an epoxy package, not known for shedding heat fast, most of the heat comes out on the leads. When they're talking about heat sinking, that refers to a diode made for a heatsink, like a TO-220, TO-247, or a stud diode. A regular epoxy-case axial-lead diode, the most common type used for homebrew, is not made for a heatsink. When they get current rammed thru them backwards they tend to die, quickly.
But... There are maximum power dissipation ratings for diodes, limits to how much power can go thru them. They're based on how much heating they can take before dying. The 1N400x series only does 3 watts. At a lowly 10,000 volts, they're maxed at only 0.3mA. Do you think 0.3 milli-amps is a large current? Because not much more, no matter which direction the current is going, will put them over their ratings and kill them.
No. There are many types of diodes, among the regular and special types. While plain doped silicon is most often encountered, there are many constructions and chemistries, both historically and currently. For example, a micro-thin layer of oxide may be involved, and voltage, aka electrical potential, is a determining factor in oxide breakdown. This is seen with water, which is an oxide, when the voltage required for electrolysis is calculated. Once breakdown has occurred, with hardly any current at all, the oxide can be damaged. Likewise other chemistries can be altered. There may also be a thin place in a substrate where the actual breakdown will occur, a concentrated effect, which will cause overheating and damage at that spot. Semiconductors can be interesting and tricky, a MOSFET can handle large currents and be killed by a single stray spark.
In the ideal world frequently found in textbooks, you can make claims that proper heatsinking will keep a diode from dying. But out here in reality, if a device is not made for breadown, such as a Zener or avalanche diode, it is best to assume it is dead, for if it isn't obviously dead there's a good possibility it has suffered damage that will cause it to fail during use under load, no matter what current was involved.
...we need to know what Dantex is using them for in order to determine if it is gonna burn out because of breakdown or if it would even reach to the point of breakdown.
Nope. It's a simple question, will 2 diodes rated for 300V in series be good for 600V? In an ideal textbook world, yes. Out here in reality, given differences in diodes between manufacturers, even within the same batch by the same manufacturer, the blanket answer is no. And best of luck if you want to test a bunch to find two close enough that'll work.
However, this doesn't mean however they can't handle higher voltages. General purpose diodes have a froward voltage drop of .7 V, Does this mean they will burn out at higher voltages? No.
And the application does matter because, although the forward voltage drop is accurately stated, the true reverse biased breakdown voltage, which is like the reverse voltage drop is 20% higher than the reported rating. So if you are trying to build a rectifier, you will say under the rating, however in certain applications, the voltage does exceeds the ratings (ie. when the diodes are used in a high voltage trigger) then you'll need to consider the inaccuracy of the ratings and the fact that the true reverse biased breakdown voltage significantly varies from one diode to another.
Agreed. If one put 600V through a 300V diode, it would burn out. There would still be 600V through each of the diodes, so they would still burn out.
