Direction/turn signal indicators making them brighter with led bulb I need help pls
Hi. I somtimes ride a 1985 yamaha ms50 pogal 50cc moped. It has an 6v electrial system where as modern day scooters are 12v. I bought a knew indicater relay for it and checked all the bulbs as the turn signal indicators are not so easy to see flashing. I mean, on average sunny day other road users would need to look hard to see them flashing. the bulbs are 6v 15w and both old and knew flasher relays gives output of 6v 40w.
I would feel much safer when turning if I had a bulb that gives a brighter flash to give other road users a better idea when im turning. I can see on the web there is a 6v 5w and 10w bulb I can try or even 6v leds but I dont know much about leds. the stanadard factory fitted indicater buld 6v 15w gives an ok flash at night, but in sunny daylight I would need to be close up to see it flash which is no good!
I don't want to change the originality of this little ped since it has been carefully taken care of over the years and has made it in intact into current times as is. I need to come up with somthing that will work and if I replace a buld with a 5w or 10w when it should be 15w I may get a brigher flash or just blow the bulb.
I wonder was there a problem or just bad design with the indicator lights on the yamaha ms50 pogal when they first came out in the 1980's as I have seen a couple of them fitted with suzuki fz50 indicators and other makes of bike turn signal indicaters on them. I don't think the flashers are faulty I feel they where just made that way. I could be wrong. I suppose there could be a bad earth on the flashers.
Sorry to go on so much about this. Im looking for your suggestions for a brighter indicator flashers which is purely for safety reasons. If car drivers can see where im turning, im less at risk of being nocked off by them. Im thinking a higher or lower wattage incandescent 6v buld or even a replacment 6v led buld ive seen on ebay but as I said. I know nothing about led bulbs or even if they will work on my moped. Would a equivalent 6v 15w led give a brigher flash than a 6v 15w tradisional incandesant bulb? can someone help me here pls
Here's the led ive seen on ebay
http://www.ebay.co.uk/itm/2pcs-E10-6V-9V-12V-24V-INDICATOR-LIGHT-BULB-LED-WL-ay-/330859527741?pt=LH_DefaultDomain_3&hash=item4d08c3be3d
these are the standard 6v 15w bulbs i want to replace with brighter led bulbs
http://directshopping4u.com/6voltvehiclelighting/P244A10
Picture of Direction/turn signal indicators making them brighter with led bulb I need help pls
