Dissolve Aluminum - Golden Book Chemistry
6
comments
Add Comment
Metal + acid -> metal salt + hydrogen
A semantic point, though; the aluminium does not actually dissolve. It reacts to form the chloride, which then dissolves.
Thanks.
Aluminum chloride can cause burns if it's not buffered correctly.
If you take the Aluminum chloride residue and bake it until it's dry it can be used to attach acyllium functional groups to benzene rings.
For a home type experiment I would use a large test tube and place about (2) 1 inch squares of aluminum foil rolled up into balls in the bottom of it. Then drop HCl onto them with a glass rod or a eye dropper. Place a small test tube over the top of the large one just to the side as to not allow pressure to build up. After a "little bit" of hydrogen gas is caught in the small test tube place a piece of cardboard over it to trap the gas in. Now remove the cardboard and place a long fireplace match or BBQ lighter in the test tube and it will POP! If there is only a small amount of the gas present, then it will flash. Too much gas and the test tube will shatter!
Please be careful.
Any chemistry book gives you just enough info to be dangerous. Do your research before you start messing around. Good luck.
Yeah, I know it's frowned upon, but I rarely get my answers from a wiki or google search. When I post, I'm almost certain to get current info, and it's sometimes helpful when the subject is srcutinized amongst other members.
[not in this particular instance] My apologies.
Anyway, does my back porch fall under controlled chem lab conditions? lol
We are doing homeschool stuff; I certainly wish we had access to a chemistry lab. And yeah, that particular book [pdf] is one of those which gives JUST the dangerous info.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
