Distortion Pedal - Need a little help!
Hello all. I am in need of some help!!
http://www.instructables.com/id/Make-an-easy-guitar-distortion-pedal-STEP-BY-STEP/step20/Adding-a-bypass-switch/
This is a 'schematic' of a distortion pedal for guitars
In this specific picture it shows how to install a BYPASS SWITCH.
I'm having trouble with it, when i turn the switch on i get nice distorted sound.....when i turn the switch off i get NO sound. (i should be having lean guitar sound instead)
I hooked up everything perfectly. Still problems.
What can I do so that when I turn the switch off I will get clean sound?
Any suggestions?
Thank you.
Any suggestions?
Thank you.
Maker Faire 2013 Slide Show!
Fried Contest Launches 5/13, HQ Celebrates with Fried Day Friday
MEH! :D A Build Night at Montana Ethical Hackerspace!
Got contest ideas? Want to help HQ staff?
Large Instructables Robot head made out of driftwood, check it out!
Call for pre-made parts!
The Instructables Green Design Contest is starting on Earth Day!
My instructable made it into Popular Science!
Orbotix wants to see your hacks - you could win a Sphero!
Transformational experience for Instructables Artist-in-Residence
Visit Our Store »
Go Pro Today »
All you need is a simple SPST switch. It will have 3 pins on it. Connect the center pin with the input jack. Then put the wire from the output jack on one of the outside pins and the distortion wire on the other. Or you can use your existing switch the same way and ignore one side of pins.
The clean sound seems to be low, but that's just fine with me. I may have to add something in the board to broaden the clean sound.
Thanks again, I had a feeling i wouldn't get a response, but you came through!!
-Grizzly
