6
comments
Add Comment
sort by:
active |
newest |
oldest
No. That is too much for nearly any technology, MosFET, IGBT whatever
Mar 3, 2009. 9:06 PMwestfw
says:
Digikey's parametric search says there are 447 PNP transistors with Ic of 3.5A or better (and up to 60A...)
Parametric searches let you search through a database based on parameters rather than on strings. VERY useful.
- Start at http://www.digikey.com and enter pnp transistor in the search field
- On the next page, click on Transistors (BJT) - Single (this gets you to the parameter page)
- Collector Current is the first column. Use shift-click to select a useful range rather than an exact value.
- Try to pare down the results to a reasonable number with the other columns. Package is a good one...
I found 2 that might be obsolete, but here are the numbers: 2N3962-ND PN5139-ND And here is a very large list of Data sheets for High Power transistors - PNP
Ooops, forgot the link: http://www.electronics-lab.com/downloads/datasheets/high_power_transistors.html
Roger Boisjoly dies at 73; engineer tried to halt Challenger launch
Follow up on the Arduino Jam Belgium
I need some help with paper mache angry birds for a party game
A new shirt
Wanna know what I'm doing with the laser cutter?
What would you make with a desktop CNC milling machine
Arduino Jam Belgium
December beard-off!
