3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Doorbell Issues
I have a problem with my doorbell, and it's driving me insane. A couple of weeks ago I decided to fix our doorbell, one that has not worked for a very long time (decades).
I replaced the grommets that go on the tone bars. I cleaned the plungers and everything. It worked just fine, until about a week ago. Sometimes it will ring, sometimes it's very quiet, sometimes it doesn't ring at all, and sometimes it will do a short ring (the ring doesn't last very long, like it used to).
Also, it is about 40 years old.
Another thing, the switch is rated at 16V, and I'm using an 18V doorbell, could this cause the circuit to not complete properly?
Here is a picture of it (cover removed)
I thought by putting hot glue on the grommets would help, but it didn't. The pic shows the glue, but now it is removed.
7 comments
Dec 8, 2010. 6:23 AMGoodhart says:
sounds like the rating of 18v. means it didn't have the strength to push it consistently, so I am glad you found a solution, albeit it may be temporary.
Dec 7, 2010. 9:53 PMIrene7999 says:
Here is a good article that explain how to Troubleshooting doorbell,hope can help you,anyhow,if not succeed,try a new wirelss doobell.
http://www.doorbellfaq.com/troubleshooting.html
Sep 23, 2010. 12:04 PMNachoMahma says:
.  To test the unit, short between FRONT and TRANS. (or TRANS. and REAR). If everything is working OK, then the problem is in the switch and/or wiring as Kiteman suggests. If it doesn't work, then you need to do some more cleaning (the plungers must move freely throughout their range of motion) and you may need to replace the coil(s).
.  The 2V difference shouldn't be a problem. Plus, the system voltage will probably drop when the coil is energized.
.  The RTV will mute the bars.
Sep 23, 2010. 11:53 AMKiteman says:
Fixed or replaced - after all, this is a maker site, not a shopping site.
Have a look at the spring in the bell-push, see if you can find something similar in your scraps box, and maybe also check to see if the contacts need cleaning?
Sep 23, 2010. 11:00 AMKiteman says:
My first thought is not the bell, but the push-switch of the wire between switch and bell.
I sounds like a loose contact or wire cracked inside the insulation.
Or maybe the spring inside the bell-push is giving up?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
