loading
Drive Shaft To Pulley
Help!
How do I attach this pulley (or any pulley) to a drive shaft?
Specifically:
This Motor: https://www.amazon.com/gp/product/B00O8UKN7I/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
To This Pulley: https://www.amazon.com/gp/product/B00004RAO8/ref=oh_aui_detailpage_o03_s01?ie=UTF8&psc=1
Toga_Dan3 days ago
https://www.amazon.com/dp/B00T6CKSGY?ref_=pfb_4edd48ldmg0g0bkb8bghd0fd70a9&tag=hydfbook0e-20&ascsubtag=pfb-P01-V02-O2-T1-HI-4DCJUB or get /make a bushing.
You don't....
john.walsh (author)  Downunder35m14 days ago
That's what I've come to realize.
Fortunately you folks gave me enough vocabulary to find:
This one
https://www.amazon.com/gp/product/B001OK8LL0/ref=o...
and this one
https://www.amazon.com/gp/product/B00T6CKSGY/ref=o...
One of those should work.
I hope the library appreciates all this effort.
Thank you both!
Looks to me like you can just slip it on and tighten down the Allen screw. And get pulley bore adapters if needed.
john.walsh (author)  filmaker200014 days ago
There is only one screw to secure it.
My thought if I tightened it would be off center and not rotate properly.
Yes, but only if the shaft actually allows for it.
Usually they are hardened steel and for the sprocket is a cut out section - not big enough for the grub screw to hold on.
But you got me thinking....
Assuming the diameters match than it should be possible to use an angle grinder or a really good file to make a small notch for the grub screw....
According to the picture you showed of the motor and shaft, there is a cut out section for the set screw.
