Dry Freezing.
could you take a liquid solution and submerse it in dry ice to dry freeze it?
12
comments
Add Comment
Anyway, this is my queries.
Freeze dry happens because you first freeze the water. Then Displace the water by sublimation. But this sublimation can only happen while the water is frozen and in negative pressure. If I wanted to do this to say,blackberries, if I freeze them normally they will crystalize and become mushy. So wouldn't I just flash freeze them with the dry ice to start?
Second. If I have dry ice flash frozen blackberries, could I then put them into a canning jar, (i suppose I'd have to keep the canning jar in the dry ice to keep the contents cold) and could I use my Foodsaver jar attachment to draw the vacuum? I use this attachment on canning jars and it draws out the air in the jar enough to make the rubber lid stay tightly because of the vacuum. But there would me only a vacuum no CO2 gas in the jar.
Do you think that would work?
Your chitosan bandage instructable step 5 doesn't use a vacuum. just the container with a small hole. would that work for letting water vapor out? I wanna try this to make cat treats and freeze dry herbs, berries and other weird fun stuff.
You make things make so much sense!!
I forgot about low temperature making it's own low pressure area! I'm so glad you clarified that for me.
I've never purposely sublimated anything, but my cat sure loved the chewy tilapia filets that got freeze dried in my friends frost free fridge cause she left the bag open. I hope to duplicate that on purpose. Thanks again for the response. I'll go reread your instructable for the details!
You might want to look up cryogenic techniques to cool liquids rapidly. Besides, dry ice is in block or powder form so you are mixing it with the liquid to be cooled. You get that cool bubbling fog effect when they come in contact.
The advantage is not heating the material too much.
What do you want drying?
L
L
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
