loading
ESP8266-01 DTH22 5 minute Delay?
Hi,
I want to add a DHT22 sensor node to my Openhab setup. A simple way to do this is by using a ESP8266-01; I have a few around. I use the Arduino 1.6.5 IDE since that is what I have. I am having problems with the timing of the loop: I do not need readings every minute or so, 5-10 minutes is more then enough; I do not need that much data. I also want to run the node on batteries in the future so less transmissions is what I want. However, when I use a delay of more then approx. 24000 mils the ESP stops working, lower values are no problem.
I have tried several approaches, none work. Can anyone help me out?
The sketch I use is below, you can see what I tried in the comments:
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#include <DHT.h>
const char* ssid = "Yggdrasil";
const char* password = "XXXXXXXXX";
char* topic_t = "openhab/esp8266-1/temp";
char* topic_h = "openhab/esp8266-1/vocht";
char* server = "192.168.X.X";
String clientName = "esp8266-1";
//time peter, idea taken from https://www.safaribooksonline.com/library/view/arduino-cookbook-2nd/9781449321185/ch12.html
const long oneSecond = 1000;  // a second is a thousand milliseconds
const long oneMinute = oneSecond * 60;
const long fiveMinutes = oneMinute * 5;
//time peter
#define DHTPIN 2 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 11
DHT dht(DHTPIN, DHTTYPE,15);
WiFiClient wifiClient;
PubSubClient client(server, 1883, callback, wifiClient);
void callback(char* topic, byte* payload, unsigned int length) {
// handle message arrived
void setup() {
Serial.begin(115200);
delay(10);
dht.begin();
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
Serial.print(server);
Serial.print(" as ");
Serial.println(clientName);
if (client.connect((char*) clientName.c_str())) {
Serial.println("Connected to MQTT broker");
Serial.print("Topic is: ");
Serial.println(topic_t);
Serial.println(topic_h);
else {
Serial.println("MQTT connect failed");
Serial.println("Will reset and try again...");
abort();
void loop()
float h = dht.readHumidity();
float t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
static int counter = 0;
String payload ;
payload += t;
//payload += ":";
//payload += h;
String payloadh ;
payloadh += h;
if (client.connected()){
Serial.print("Sending payload: ");
Serial.println(payload);
if (client.publish(topic_t, (char*) payload.c_str()))
Serial.println("Publish ok");
else {
Serial.println("Publish failed");
//peter
Serial.println(payloadh);
if (client.publish(topic_h, (char*) payloadh.c_str()))
else {
//peter
else {
// delay (20000); //WORKS FINE
// delay(5*60*1000); //STOPS AFTER FIRST READING AT STARTUP
delay(fiveMinutes); // STOPS AFTER FIRST READING AT STARTUP
dudes1 year ago
You could try using the sleep function of the esp8266. It's very easy and worked perfectly for me. Although it may be difficult to access the sleep pin, depending on your breakout board.
PetervdPol (author)  dudes1 year ago
thanks. I have ESP-01's and soldering the necessary wires is beyond my skills I am afraid...
