Echo independent color
Hello i'm makin a super advanced bat file for my comp noob m8 and it looks really complcated so i was wondering is it possible to color certan lines
e.g if their was an error it be in red with the rest of the screen in green
I ALREADY know about 'color 0a' but that fills the whole screen. I need a small block or just a line to be different & stand out
1-10 of 11Next »
@echo off &setlocal
:: Create a backspace character:
for /f "delims=#" %%a in ('"prompt #$H# &for %%b in (1) do rem"') do set "Bs=%%a"
:: Redirect a string of dot and backspaces without line break
<nul >"Hello World!.#" set /p "=.%Bs%%Bs%%Bs%%Bs%"
:: Process FINDSTR
findstr /p /a:F4 . "*.#"
:: We need a linebreak because there was no in the file.
echo(
pause
This is not my code, it is g-one's.
Here is my edited code:
@echo off
for /f "delims=#" %%a in ('"prompt #$H# &for %%b in (1) do rem"') do set "bs=%%a"
setlocal enabledelayedexpansion
color 0a
title Colour Changer
:start
cls
set /p text=Type the text you want to change colours here:
set /p colour=Type the colour code here:
"%text%.@" set /p "=.%bs%%bs%%bs%%bs%"
findstr /p /a:%colour% . "*.@"
del %text%.@
pause >nul
goto start
Have fun!
NachoMahma10 years ago
. Is this what you're talking about?
It looks like your talking about the prompt command. Unfortunately, it doesn't cover colours.
Padlock Padlock9 years ago
O... I forget to attach the file. But here it is...
XECHO.COM867 bytes
wait how do i make it colored?
Padlock9 years ago
I don't think you can make the text smaller, you might have to find a different text printing command
Padlock9 years ago
Of my extensive collection of command line tools, I have this one tool...(attached) It makes large font but it can be colored differing colors. Note: I did not make this program... It was written some time ago... in german (I think?) So the help argument does no good unless you translate it.
westfw Padlock9 years ago
I believe that you'll have to have loaded up the "ansi.sys" console driver (which interprets vt100-like escape sequences) or it's modern equivalent (ansi.sys is like DOS 3.1 or perhaps even earlier.) After that's working, the echo sequences with
\033[1;38m
should work (perhaps use an actual ESC char instead of \033...)
See http://en.wikipedia.org/wiki/ANSI_color
daWISEMAN9 years ago
echo -e "\033[40m\033[1;31mLight Red \033[0m replace 1;31 with 1;30 through 1;38 for different colors.
1-10 of 11Next »
