Electromagnetic pulse generator plans?
57
comments
Add Comment
And what's wrong with a SmatBoard? I use one all the time.
If you want true emp pulses, you would need to do a little research. Maybe combining a high frequency pulsing circuit that pushing a good amount of current into pancake coils. Look up Nikola Tesla and Pancake coils to see what I mean. It is my opinion that you would not want any ferrite in any of the coils if you expect the electromagnetic field to disipate in the surrounding air either. Pancake coils are perfect for the job. Maybe a nice stack of them, and you will kick a pulse directional much stronger than firing a nail through a coil of wire with dynomite. Not to mention, you might survive when you fire it off.
look into that on anarchists cookbook your onto whats called a HERT or somethin.. read that too
Possibly a smaller EMP (coil type, range of a few inches for soft crashes) could be made with a bunch of camera flash caps in parallel. That's more doable, and I might try it some time.
Big caps at here: http://www.electricstuff.co.uk/destructotron.html
That's 5kv 220uF. Would probably make a good EMP bank for the vaporizing wire method.
For you... have a look here
http://eiu.org/experiments/i-bomb/
They don't tell you how it is made, but i can think the device is like this
<<<<<<DANGER>>>>> <<<<HIGH VOLTAGE>>>>
Power (AC) > switch > rectifier > LEET step up transformer :) (like a stun gun... but more) > a high power diode > crapload of capacitors with the correct voltage > arming switch > fire > long long cable > to a excessively wound coil of high (in diameter) wires.
Don't worry about my little plan, it is not mobile at all... and if it is made... it would be pretty big... too big to hide from other cops :)
But it is just enough for you to test your idea out.
I didn't mention any safety, so its your fault if you get hurt :)
I am not liable for any damage or loss of life in trying my idea out.
Hope it helps
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
