3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Essential oil/Alchohol/Solvent purification and separation
Hi,
I have a lot of impure essential oil that has a lot of water in it and was thinking about ways to get some of the water out. Would salting out with Epsom salts work? I've seen an Instructable where a nonpolar solvent is used to extract nepecatalone http://www.instructables.com/id/DIY-Kitty-Crack%3a--ultra-potent-catnip-extract/ would one be able to use a solvent that is immiscible (I swear that's a word) in water to get the constituents that are not water soluble out of the water?
Also can common solvents (I'm thinking alcohol, acetone, and toulene) be salted out to increase the concentration? Would this work with dilute hydrochloric acid?
-mitch
24 comments
Mar 15, 2009. 3:38 PMlemonie says:
Oil and water usually don't mix. Adding ordinary (table) salt should help to separate the two liquids.
Alcohol (ethanol) and acetone are water miscible, but dried (oven) Epsom salts will remove water. Toluene is unpleasant and has a high boiling point, I don't think aqueous acid will help you. Diethyl ether would be great, but you're unlikely to be able to get any.
L
Mar 15, 2009. 4:30 PMlemonie says:
You want to make dry hydrogen chloride, or concentrate dilute aqueous? L
Mar 15, 2009. 4:51 PMlemonie says:
I don't think you can (easily) concentrate this stuff. Sulphuric, yes. L What do you want it for?
Mar 15, 2009. 6:11 PMthematthatter says:
the problem with using HCl to neutralize NaOH is that both are strong. Any excess of one of the reagents can lead to either a highly acidic solution left or a strong base left. The safer thing would to use vinegar. You can flood the spill with vinegar and not get a chemical burn when you try to clean it up. Plus vinegar is pretty cheep I dont think HCl is reactive enough to strip the Mg off the SO4 ion. And if it did you would end up with MgCl2 and H2SO4, and Sulfuric acid is pretty nasty so i could see it dissolving the Magnesium chloride so you would see no reaction.
Mar 17, 2009. 5:21 AMthematthatter says:
heck yeah. ever see fight club. But yeah, vinegar is for bases, and baking soda is for acid spills.
Mar 17, 2009. 4:25 AMNachoMahma says:
. Centrifuging might work. Maybe.
Mar 15, 2009. 5:59 PMthematthatter says:
your going to need a "still" to do that.
Mar 16, 2009. 1:03 PMlemonie says:
The still isn't going to be much use as these oils were extracted with steam in the first place. L
Mar 16, 2009. 2:36 PMthematthatter says:
how would that make a difference? we distilled commerical essential oil that was @ 30% and made it ~97% it was lemon grass.
Mar 16, 2009. 2:45 PMlemonie says:
Was it mixed with water? This oil/water mix was produced by steam distillation, you'd expect something similar to happen if you tried distilling it again. Final clean-up perhaps. L
Mar 16, 2009. 1:04 PMlemonie says:
Freeze the water? L
Mar 17, 2009. 12:26 AMlemonie says:
Yes but you could just thaw it out again - easy to try, nothing lost. L
Mar 15, 2009. 6:14 PMthematthatter says:
you can use a fractional still and each distillation would be an almost separate item. Make sure your thermometer is in the right spot and its accurate and you can toss out the water once you get to it.
Mar 16, 2009. 10:12 AMthematthatter says:
There is plenty of diagrams on line, they mostly use an "organic chemistry distillation kit" Very expensive to buy and maintain (cheapest piece is about 20 bucks). If your resourceful you can build one pretty easily out of plumbing parts, same rule about the thermometer, you dont want to toss the good stuff because your thermometer is in the wrong spot.
Mar 15, 2009. 4:00 PMGoodhart says:
slacked lime might work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
