Evaporating Water Drops
Ok, so I was using the Water Drop Paint effect iBle, but when I was done, I realized my plan had a big downfall - it's almost dark.
Is there a good way to evaporate the water drops without using wind, which would blow the drops around (i.e., blow dryer)?
Thanks!
Picture of Evaporating Water Drops
guyfrom7up10 years ago
jusr reading the title I got a grade idea for an instructable that suspends water in mid air using compressed air. Or use a hair dryer and watch it evaporat in mid air. Only problem is water drops are naturally pretty aerodynamic.
That would be hard... you'd need to find the terminal velocity of a drop of water! Good luck with that! Then again, it'd be cool to pour water down a tube with an updraft traveling at its terminal velocity.
Kiteman zachninme10 years ago
Here's what you need:
Terminal velocity of raindrops.
Kiteman10 years ago
Halogen desk lamp, held close?
Bran (author)  Kiteman10 years ago
Would that have any adverse effects on the fresh (but dry) spray paint?
Kiteman Bran10 years ago
Not a clue! Try it on a sacrificial piece to check.
Well, I figured I could always replace my muffs, as they were just cheap ones (that I found)! =D
It didn't seem to harm it, but I'll have to redo one side, as the effect was in-line with my other.
Thanks again!
Alright, I'll try it. Thanks!
zachninme Kiteman10 years ago
That sounds good...
