Eyeclops night vision 2 review
              I haven't used the eyeclops night vision 1, so I can't make any comparisons. From the photographs, you can see two sets of lights on either side and a ring of leds around the camera lens. When in low power or "stealth" mode, only the lights on the sides are on. In the dark, the glow very dimly, you have to be 3 feet or less to see  them glow and it's still very dim. When in long range mode, the lights on the sides turn off, replaced by the circle of lights in the middle. These are clearly visible at close range, even in daytime, although still with less intensity as a red led. The knob toward the eyepiece is for adjustment of eye. I don't see what it does. The knob on the end near the camera adjusts focus. Seeing things at long range clearly and close range clearly require different adjustments. It's real infrared technology. You can switch between "military" and "spy" The difference between "military" and "spy isn't much. One of them is normal, infrared vision, and the other applies a green layer, making it seem like the view from COD. The 6 knobs along the middle don't do anything.
 It uses 7.5 volts using 5 AA batteries. There there is only one LCD, despite it claiming dual LCD technology. The skirt on the eyepiece is detachable. The strap feels pretty cheap, I plan on making it into a head light sort of thing later with paracord or elastics. Objects appear closer and you have no peripheral vision though. The latter problem is something all night vision goggles have. Overall, it's not a bad deal for a $50 toy. The most annyoing thing is that the dials are a bit loose, so running or shaking them makes a rattling sound, giving away your position if you were doing covert sneaking around or playing a prank.
       This is useful for scanning an area in the dark without revealing your location. It's also useful for night spying. What this toy cannot do is read words or anything in detail the size of words. Although navigation is possible, the lack or peripheral vision is a problem.
Possible Mods: Add an airsoft or rc car battery to replace the 5 AA batteries. The half near the eye piece can be cut off I think. You would have to add a new compartment for the batteries though and the light from the LCD would leak out. I would add a strap of two so you can use it hands free. I would also attach a smal telescope or lens backward so objects appear normal distance. The peripheral vision problem could hypothetically be solved the same way people make DIY fisheye lenses. Extra infrared LEDs flashlights and other lights could be added around a house, allowing you to cover up the lights, not exposing your position. Another idea is infrared led throwies. They would function like NATO infrared glow sticks, allowing people to track a certain target or where to fire.
Picture of Eyeclops night vision 2 review
ry259207 years ago
 For how much it is... It's not great, you could make the same thing for less than $10-$15 for the illuminator and all you need is a cell phone camera or a camera which doesn't have an IR filter.... For the review, I think you did a great job... You probably could've done better by breaking up the paragraphs and indenting... But other than that, nice job.. 3.5 stars
starwing123 (author)  ry259207 years ago
Thanks. The only problem with that would be making a skirt or something to block out the light from the LCD. The point of this after all is stealth nigh viewing. The majority of a product's cost is usually not the technology or actual manufacturing price, but the cost of developing the ergonomics.
