Fake Bones And Organs For Ballistics Gel Dummy
I want to make a ballistics gel dummy to test assorted weapons from video games on. Like pipe wrenches, crowbars, hammers, and kitchen knives. To do this I want realistic fake bones and organs to simulate the damage the weapons would cause to those. How would I make them?
1-10 of 16Next »
This frightens me a little, hopefully you are not my neighbour :-p
creepy0000 (author)  ThirdEarthDesign1 year ago
The odds are slim. Also why?
If I looked out of my window and saw a neighbour hacking away at a ballistics dummy with a pipe wrench, it's a possible cause for concern. I'd wonder if it was preparation for the apocalypse.
Recently had a contest for that here: https://www.instructables.com/contest/survivalready...
You're not preparing?
I had a thought about the problem here and the Mythbusters always kept popping back into my mind....
For blood they used rubber hoses and ballons.
The bones for some hand dummies were made with fibreglass resin and some plastic, later they used better substitudes after making several comparison tests on "donated" cadaver bones.
If you want real organs the best replacement would be pig organs as they are the closest you will get to real human ones.
Problem is obtaining them as in most countries you will have a hard time getting a liver and brains are off the menu anyway - but they can be replaced by your favourite flavor of jello and vanilla sauce.
If the size difference is no big deal then lamb bones come close enough to human bones in terms of breaking and crushing them.
Pig, cow and other big animal bones are usually much stronger than ours when you hit them and they break in a different way.
Maybe time to watch some Maythbusters to get ideas for your dummy ;)
Well, now I'm thinking about it!
Toga_Dan1 year ago
http://www.sciencedirect.com/science/article/pii/S...
I Googled ( tensile strength ballistic gel) got nothin much. Compressive strength, yes. And that seems to be mostly there with higher speeds (1000fps, for instance) . But a real body has tensile strength, too.
Kiteman1 year ago
Oddly, I had this same conversation with my youngest son.
We decided that a good budget option would be broom handles, cut to length. Simple joints could be made by inserting eye-bolts into the ends of the dowels and connecting with wire or paracord.
creepy0000 (author)  Kiteman1 year ago
To simulate bones? Wood is strong due to parallel strands of cellulose held together by a binder. Bones are strong because it's made of calcium phosphate and other minerals, and it has collagen fibers arranged length wise to make it flexible. Also I want them to look real. And what do you think I'm doing by the way? Joints? Why would a ballistics dummy need joints?
If you want realistic results, then, yes. Joints. How much tensile strength does gel have? Bet you could pull an "arm" right off. In the real world, that'll probably take 1000 lbs.
1-10 of 16Next »
