loading
Favourite Primary and Side-arm (K'nex)
If you could only make 1 primary and 1 side arm to take on your stupid little brother in a K'nex war, what would they be? Personally, I would take Dsman's DD-27, and Dsman's side-arm.
1-10 of 52Next »
TheDunkis8 years ago
Well now my TDS is obsolete. Now I'm using my oddassault pistol but I'm not sure what to do about a primary. You know I think I might stick with some sort of rubber band gun with Knex pieces. Basically like a mini semi auto sling shot after all...
you know, I just recently made a gun that would work very well along side the oddassault pistol if i can give it more range. it is really more or less not my design. i simply took ironmans mag(the one that used the bendy rod) and built a gun around it. now, the mag is non-removable, but that's the best part, i left the top part open like on the mag so you can load the gun anytime you have, you just stick another ammo piece in the slot. it would work great in a war because when ever you see a piece of ammo you can just load it into the gun right there. it's almost like having a bottomless mag because you never seem to run out of ammo. and you don't have to worry about the bands breaking ether. i gave it IAC's trigger(simply because it was the best trigger that would fit in the tiny space). the only problem is the ammo, i have been using iromans ammo for it and it just flips around in the air. i need to figure out a better ammo for it before it really is any good.
That sounds perfect for a breech-loading bolt action. I may try one using the idea, but probably not true bolt action. The idea is for an internal mag which can be loaded via the breech, i.e. you just push rounds in on top of each other then close the breech.
ya, thats exactly what the gun does, the only difference is you don't have to close the breach, a hole is left there for very easy loading.
Sounds good; any ideas when it might be posted?
not really, i have some more plans for it(IE. changing the ammo if possible) and am not really happy with it right now(really, if you saw it almost none of it is really my design, i just took the mag, and shoved on I_A_C's pistol trigger. it looks like a bbkwg and I_A_C's assault pistol combo. if i could change the ammo to something better, i could get a better range out of it. it as easy as it sounds though because really takes some thought to make the mag just right, since if i do make the ammo smaller, i will have less of a area for the ammo to stay straight(the breach take up half of the top of the mag, the other half creates the barrel and if it is to short, the ammo won't sit straight, but start with it angled with half of it up the breach). but if i do make the ammo smaller, i could also make the breach smaller, but this could be to small for knex to allow(i can't have the barrel part be so small that i can't create it with knex pieces without cutting them.) right now, it is nowhere near post worthy, but i hope to have these problems solved soon, and finally post something(i wonder how long it has been since my last posted project...)
So far it seems when it comes to distance there are only two types of ammo that go anywhere- Red which would be better off with fins in the long run and oodammo but it's rather hard to use. So in other words it's like an upside-down hopper that's less prone to jams? Sounds good. I nearly forgot. I was going to use Zak's latest BA for my primary. Maybe if I could mod it or make my own to make it just a little better.
i find that a grey rod with a read connector on my newest version of the DD-27 works just fine for range. actually, the mag is right side up, and the breach has a hole in it, so you just load all the ammo through the hold in the breach, making it easier to load and still have a mag(the disadvantage of a mag on a battle field is that it takes you 2 minutes just to load one piece of ammo into the mag, with this you could load the whole mag in around 20 seconds.
knexfan91828 years ago
mepain sniper and tds2 even tho i have not built it yet
I can guarantee there are few side arms that can compete with the TDS2.
1-10 of 52Next »
