Game Gloves
I've been looking online recently for some sort of "glove" that you would wear for gaming, instead of having a keyboard. Didnt really find anything.. at least in my price range. So i am going to get the Makey Makey tomorrow from a trade with a friend, i figured this was my best bet. My idea for this glove would be that it have either foil on the tips or that sewing yarn that can be used as wire. There would be a thin Aluminum Sheet that you would tap with the appropriate finger. The aluminum sheet would act as the ground. My other idead would be instead of having the Aluminum Sheet have the tech yarn in the palm of your hand, but this would get uncomfortable after time. I want to make this so i could possibly in the future have two gloves one for each hand. Also, if i was to use the special yarn for electronics, i would have to wear to gloves since the yarn would weave in and out of the glove grounding to your finger. Most likely going to be working on this tomorrow or as soon as i can get some cheap gloves. I'll upload pictures then.
any suggestions?
caitlinsdad4 years ago
Just look up "soft circuit gloves" in the search above. You could make your own fabric sensor switch also. The Peregrine gamin glove could probably be functionally replicated by sewing guitar string paths on the outside of the glove. With a fingertip touch contact, you would just need a microcontroller to interpret the different resistance values at the defined zones to trigger the game. Good luck.
