Gluing Plastic to Glass??
What would be the best way to glue plastic to glass?? I have some Epoxy but I don't know if that would hold.
Goodhart9 years ago
Superglue needs a decent amount of contact area (it doesn't fill space well) so if the surface is "rough", porous, or a "rounded edge", it may not hold well. But then, most glues will not. A gap-filling epoxy that can be build up a bit may do it (and it will hold better if the glass can be scratched slightly) .
wesie429 years ago
Forget the super glue get Gorilla Glue Or Gorilla double sided tape
Mr. TiKi (author)  wesie429 years ago
I think I might try the double sided tape. Thanks for the suggestion.
yup :)
Kiteman9 years ago
Depends what you're trying to do. Super-glue should work for a lot of uses.
Mr. TiKi (author)  Kiteman9 years ago
Thanks for the comment. I'm tring to glue a plastic project box to a glass bottle.
If it's not too heavy, it should. Make sure it's supported for a few minutes as the glue dries properly.
