(HELP) Linking Wireless Pir Sensor To Wireless Chime
Hi,
trying to get a wireless PIR sensor to activate a wireless door chime...
Given up trying to get the PIR to transmit the same frequency as the chime so now trying to get the PIR to switch on the wireless doorbell chime.  So in theory, motion activates sensor, signal from sensor goes to door bell button, signal from door bell button goes to chime.
I've attached wires to the bell switch, but don't know where to attach them onto the PIR:
experiments so far have activated the chime but it stays on so I think I'm just shorting something out.
Also, should both power sources (for PIR and doorbell ringer) remain as PIR is 9v and bell ringer 12v?
Hi res pics below, thanks to anyone for their help and advice!
Greg
PIR transmitter
Front
http://i.imgur.com/77xcEcx.jpg
Back
http://i.imgur.com/8PqwSBl.jpg
Doorbell Button/transmitter (wires tied on switch contacts)
Front
http://i.imgur.com/VW5OAGz.jpg
Back:
http://i.imgur.com/SLOchYn.jpg
gregoire500 (author) 4 years ago
hi, thanks for the reply,
The wireless PIR sensor is an off-the shelf security unit that has its own processor that activates the transmitter and an LED-I assumed that this output would then be capable of sending an electrical current through the self-added wires that are connected to the wireless door bell button contacts, which in turn would operate the bell transmitter/processor and operate the wireless chime receiver unit?
Is this incredibly naive? ; /
caitlinsdad4 years ago
I think the part you are missing is: motion activates sensor, microprocessor or similar logic circuit checks to see if PIR output signal is above a threshold value, microprocessor or similar logic circuit by way of relay or directly closes the switch connected to your doorbell button...
