loading
Hard drive motors?
I need to get a harddrive motor up and running, it has four pins for power, does anyone know exactly what these pins or which is which, the motor is from a harddrive from an old xbox, i worked hard get this wretch out all the way down to the motor, honestly microsoft should build bomb shelters, and the casing of the hard drive is pretty tough, on of the boards on it needed some friendly persuasion from a hacksaw and a hammer after I removed the apparent retaining screws, all 7 million of them, by the way I may do an instructable on how to open an old Xbox with nothing more than a swiss army knife, and it doesn't get damaged at all. To figure out the pins is all I need, left to right arrangement would do I have figured out which way up the bottom is but the crazy hieroglyphis in microscopic size reveal little about the connections,
1-10 of 16Next »
swaxman1 year ago
I didn't answer the question at hand , can you use a pc fan brushless motor to run a stepper motor . Yes I'm sure it's possiuble
You know you're answering a 6 year old question don't you ?
Dooblammer7 years ago
Has anyone tried taking the controller circuit from a brushless DC computer fan, and wiring it to a hdd "stepper motor"? They appear to operate under the same principles.
Yes ! Pc fans do run other brushless motors ive done it , bysoldering 4 wire onto the 4 copper wire terminal terminations usually marked" wxy" no4 wire is soldered onto ground or "gnd" , next step is soldering the 4 newly connected wore to your 2nd parasite motors copper wire "wxy and gnd" terminals. some of the time the terminals are not marked and you must use guess work to connect what you beleive are the correct corresponding terminals on the parasite, sometimes if you connect the wrong terminals together the motor really struggles to spin without randomly changing direction , it may also spin but its low rpm and bery limpyyou gotta be really careful not to damage courier . You must have the two bearings and retaining clip and fan magnet back on the housing . Because to run a parasite motor off your host motor the host motor must be running as normal, I've tried this method twice connecting a pc fan to a VCR Billet Ring brushless motor.
they are incompatible in 2 ways. it still may work and may not work phases - hard drive is 3 phase motor and fan circuit provides 2 phases only (it may still work with some inefficiency though) power - hard drive motor is more powerfull than fan so it may overload the fan circuit most hard dive circuit boards will spin the motor if you give them 12 V (without drive heads or ide cable connected)
lewisb423 years ago
You can use a brushless electronic speed controller (Brushless ESC) like the kind used in R/C cars and aircraft. I actually have a quick write-up here, from a project a couple years ago: http://www.double-oops.org/projects/toxic-asset/repurposedharddrivemotor
You can use the magnets from inside your HDD and a 75 cent reed switch to get that stepper motor spinning super fast. No complicated circuit required.
Here's the video tutorial: http://jaytube.org/share/PueF3b3XXBo
UPDATE : The URL for my instructional video above is changing, I'm dropping the Jaytube domain in March 2014. The new URL is:
http://spottedmarley.com/share/PueF3b3XXBo
Sandisk1duo7 years ago
did you keep the controller board?
Goodhart7 years ago
Isn't that a stepper motor ?
1-10 of 16Next »
