loading
Harvest Grain- with a Hedgetrimmer?
Has anyone tried cutting tall grass with a hedgetrimmer? It does resemble a sickle bar mower, at least superficially. I've never quite gotten the hang of the scythe, and although the gas chainsaw does work, it's an awful lot o noise. This year, the slender wheatgrass, which is usually xeriscaping and erosion control will be harvested for chickens !
I'm thinkin of buying a Ryobi cordless trimmer.
1-10 of 13Next »
Toga_Dan (author) 2 years ago
http://www.target.com/p/greenworks-g24-24v-cordless-20-extended-reach-hedge-trimmer/-/A-16917010 any red flags on this one? Having the pole handle and hinge points may mean an effective power scythe.
The worryingly good price? Or maybe garden stuff and lithium ion batteries are cheaper over there...
A pole trimmer seems like the best option for what you want to do.
caitlinsdad2 years ago
I tried using one of those plug in electric hedge trimmers with the cutting bar row of teeth to clear out a really overgrown garden. It does work on weeds and tall grass but... The cutting bar which each tooth is like a small bypass pruner, will jam often with stalks too thick, twigs or get caught up in vines that are too green to shear off. Slender weeds will just get bent and pushed out of the way. My technique was to "rake" the surface and try to cut a path. Using a string trimmer has its own problems of needing to replace the string often as it wears and it flinging up stuff as it cuts.
Maybe you need to mod a snowblower and make your own combine machine.
Depending how much space you want to cut, cordless batteries may not be up to the job. One of those cordless trimmers may be the equivalent load of my cordless reciprocating saw and that is only good for a few good cuts. Landscaping tools probably need to be gas engines for the power.
Toga_Dan (author)  caitlinsdad2 years ago
Funny you should mention snowblower. My mower, adapted to cutting tall grass by removing the front edge of the body, such that the blade hits the grass first, throws grass, much as snowblower throws snow. But now I want to collect grain for chickens, not just throw seed, stalk and all to the wind.
A petrol trimmer would be just as noisy as a chainsaw but makes short work of tougher grassy stuff, the kind that attach to a strimmer (weedwhacker) are actually really convenient because you can angle it and sweep along at whatever height you like.
Alternatively a brush cutting blade with a guard of some sort sitting over the top of the blade (so everything that falls on to it doesn't get minced) might be better.
You might achieve it with an electric trimmer, specifically the hybrid you mentioned by running it a bit slower if it has a speed control. That's a guess based on experiences of cutting with my big trimmer, at full tilt the blades can end up bouncing most of the stuff out of the way instead of letting it in to the gap to get sliced up.
Hey, welcome back. Ibles is a place where you check in but can never check out.
Hey, thanks it is indeed, during my absence one of the many things that happened involved becoming acutely aware of the finer points of greenery murder...
If you were a lumberjack, that's okay...
I have been wearing flannel... No lots of drama, around work and house stuff mainly then a baby arrived, she seems to drink a lot of milk and humours me when I try to entertain her, so for now she can stay.
Been there, done that. Make to keep sane.
1-10 of 13Next »
