loading
Headphone LED Question (HELP)
I have been making headphones and need some help. when wiring I soldered the red wire to the red wire, and the blue wire to the blue wire. It works fine but i wanted to add an LED, can I solder the led between two of the red wires? If I can't, can you tell me another simple way to wire one so it runs off the headphones? PLZ HELP!
1-10 of 12Next »
aja7476 years ago
take a meter and measure the voltage. most leds operate at 5 volts.
Gjdj38 years ago
Just a question... Are you planning on turning this into an instructable? Because if not I'd love to.
NetReaper (author)  Gjdj38 years ago
Sorry, but it doesn't work. I will be making an instructable on my steampunk headphones, but the LED had to be hooked up to a different power source...
have you tried turning the volume all the way up? check the polarity?
NetReaper (author)  tech-king8 years ago
When it's up all the way it flickers and lights up some but is just too loud!
try adding a filter capacitor to help with the flickering, but i think you will still need the volume way up.
by ears surrender, im just hooking it up to a doble A
i think you can solder in the led just fine.
I know i can solder it, but will it work?
if you splice it in with the red wire, it will flash more or less in time to the music, assuming the music is loud enough.
1-10 of 12Next »
