3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Help: Attatching Trolling Motor to PVC Framed boat
Well I am in the process of finishing my PVC John Boat and I need to figure out a way to attach my trolling motor to the back. I was thinking of attaching a 2x4 or 2x6 piece of wood to the back but the only way i could think of attaching it was to drill a few holes in the wood and zip tie it to the back. So I am hoping one of you could give me a suggestion on attaching it securely. Thank you in advance I cant wait for the boat to get in the water with a motor and my instructable to be finished aswell.
6 comments
Jun 3, 2007. 7:36 PMNachoMahma says:
. Great job! Doesn't NachoMahma at least get mentioned in your iBle? ;) . I didn't realize your were showing just the transom in the picture above. I thought you had a really funny shaped boat bottom. LOL
Jun 2, 2007. 7:52 PMNachoMahma says:
. And I'd go with more than two clamps - I don't think you realize how much torque you're dealing with. Remember, the thrust put out by the motor/blade is multiplied by the lever. Eg, if the motor puts out 100# of thrust (just grabbed that figure out of thin air, may not be close to what you're using) and the lever is 12" long, that's 100 lb-ft at the mount. 24" = 200 lb-ft, etc. Running the motor as shallow as possible will help.
. Since your mount will be so low, I'd install a 2nd 2x4 at the front and box it in (add sides attached to the mount and 2nd 2x4) - maybe even add a few studs in between. Probably don't need to clamp side 2x4s to PVC.
Jun 2, 2007. 7:38 PMNachoMahma says:
. The red line that shows how long ~17in is.
Jun 2, 2007. 6:51 PMNachoMahma says:
. I'd try worm-gear clamps with "rubber" between the metal and PVC. Add an angle bracket (pre-drilled for your board - I'd use a piece of plywood) before you tighten it up. Use as many as you need to handle the power. . You'll probably need some bracing running from the top of your board to the long run of you frame (at bottom of your dimension line).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
