loading
Help Build a Giant Inflatable Instructables Robot
Can you keep a secret?
For the Austin Maker Faire in October, I'm hoping to build an 8-foot tall inflatable Instructables Robot. I want it to be easy to find the Instructables booth.
For his wedding, Saul, built an inflatable elephant using many of the techniques from inflatable kite design and papercraft. There's a lot of CAD work required, and since I know there are some people here much better at Rhino and Blender than me, I'm asking for help. If we can pull it off, you'll get the joy of having something you designed be made very large.
Here's the process and where you can help:
1) creating a model of the robot that is appropriate for cutting in fabric, sewing together, and inflating. chooseausername did a brilliant job here, but the model has too many polygons, and just reducing the number of polygons in his model results in something that doesn't quite work.
So first, I need a model of the robot that is less than 1000 polygons while still retaining the robot's personality. Also, since it will be inflated, the robot's wheels should be retracted (its legs should just be cylinders of the same height as its legs plus wheels). We can print on the fabric, so the line on its belly doesn't need to be physical, but its buttons, eyes, ears, and antennae should stick out as they normally do; no need for individual fingers. Make sure all the normals point outward in the model.
Saul isn't quite ready to share his CAD files, so I've included screenshots of his elephant as an example. The full grey elephant has 1000 polygons.
2) modifying the model to account for real-world limitations and to make it easy to import into Pepakura Designer. As the elephant is symmetrical, Saul cut it in half, split out various body parts -- ensuring that they exactly fit back together on the vertices of the polygons (seam lines for sewing), -- and made some part of the ears a single piece of fabric which would not inflate. In the robot's case, we would probably split the legs, body, head, and ear-and-antennae assemblies. The antennae will probably need to be a slight larger diameter than they normally are. Since the robot isn't symmetric, we'll keep it whole.
3) using Pepekura to create panels
4) arranging the panels, adding seam allowances, and sewing instructions.
5) repeating steps 1 - 4 to create the bladders for inflation with a model that's slightly bigger than the skin.
6) getting a factory to cut and sew everything together.
As you can see, step 1 is the most important part. If you'd like to help, create a model of the robot, and add it to a step of the collaboration I've started here (PM me for an invite):
https://www.instructables.com/id/ETZ3QJSFKD1LWHU/
We definitely have more than one person working, as I'm sure everyone will have something valuable to contribute.
If you're interested in other giant inflatable creatures, leave a comment here. If we can streamline this process, we might make a complete zoo!
1-10 of 94Next »
ewilhelm (author) 5 years ago
More coming soon...
Looks familiar...
This project is alive again!
Thanks to some unreleased Autodesk software, I was able to make versions of the robot that should import nicely into Pepakura designer. Check out step 4 of the Instructable to see those files.
What software do we need to read those files?
http://www.tamasoft.co.jp/pepakura-en/
Thanks!
caitlinsdad8 years ago
We can figure out how to put a man on the moon but it is way tougher to create an inflatables Instructables Robot...
This is an ambitious project but I would love to see it finished. Would you bring it each year or would you give it to someone on the instructables team? (or are you on it?) I am only 14 now and have no way of getting to maker faire but when I am older (and can make it there) I would love to still see this at the maker faire each year.
I am only a lowly peasant that sows the seeds of discontent around here, I am not part of the staff. I just happen to live in a place(NYC, the greatest city in the world...not really) where they decided to have a Maker Faire and Instructables set up a booth there.
Anyway, build it and put it up as an instructable. Maybe the powers that be will recognize your awesomeness and use it at a Maker Faire. I brought along my Stargate Gong and they did display it at the booth though.
So you did finish it and you were able to display it?
1-10 of 94Next »
