loading
Help Identifying unknown Transformer
Hello
I got this transformer from an old ups, there are four wires on the primary side black, blue, green , yellow and two on the secondary red and blue. This transformer used to charge 12v 7.5ah battery also converts it back to 220V in backup mode.
Tried testing its output and got this
(Mains 220V)
Black to ground
Blue to mains-> 7.9v on secondary
Green->5.5v
Yellow->6.5v
Connecting Blue and Green to mains and it was a shot circuit and blown my fuse. I want to use this for making a decent power supply 12v+ output, is this possible?
I also saw this video https://www.youtube.com/watch?v=mc4GZM-kFUY&hd=1
The guy is using his ups transformer for generating hv to power cfl using tip122, i am not sure how to do this using my transformer.
I need to make use of this transformer somehow, otherwise its just eating dust at my home.
Picture of Help Identifying unknown Transformer
1-10 of 16Next »
SatishK851 month ago
Can i use that transformer as a center tape transformer 12-0-12
sensujon2743 months ago
it is the 12-0-12 x-former ?
a_hakeem1 year ago
I have the same problem with the same type of transformer
It is taken from MERCURY UPS but the transformer has an other part no.
UCBL30-5j06-01c
So please help me to find out how to use it
Thanks in advance
Clarkdale44 (author) 2 years ago
Well, there is another problem, even though i connected it to the bridge rectifier and capacitor, this big and bulky transformer is only good for small things which works on low current. When i hooked it up to my 12v cfl driver, it didn't even blink. Even though the output from the transformer was 12v, there was a huge voltage drop upon connecting it to the cfl circuit, almost 5v decreased, 12 to 8v. It all suggests that this transformer is of very low amps... How do u think i should deal with this. Is there any way i can increase its current capabilities?
You can't change the power output except you want to rewire the transformer.
Well, i just plugged it with bridge rectifier and 1000u cap and its working ok now.
When i connect Black to ground and blue to phase i get 12v
yellow to phase i get 8v
green to phase i get 7v
Even tested with voltage doubler, 24 volts stable.
Well done, so I take it you have some good use for it now?
Clarkdale44 (author)  Downunder35m2 years ago
Yeah... I have plenty of power supplies now for my projects. At least this transformer is being used now instead of eating dust.
First it would make sense to measure the resistance between the different wires.
Since it will be low you need a proper Ohm meter or use a fixed DC current and a voltmeter.
It it really was used to get the 220V back I would be surprised, so please check if the outlets of the UPS are connected to the transformer more or less directly.
Reason I doubt it is because it would be a pretty weird ciruit to do the job.
Once you got the resistance sorted you will know what wires can be used for a proper test.
IMHO the safest way is to feed 12 AC into the secondary and measure what comes out the other end - might be better to use something that can handle the load or to put a resistor between source and transformer to limit the current.
1-10 of 16Next »
