loading
Help Needed
I've almost finished my M4 SOPMOD. One problem. I need help making a SOPMOD kit. If you want to help, you can be a collaborator in the 'ible.  Also, for my next project, I would like to make an XM29 OICW.
I've included a picture for those of you who don't know what that is. I'd like it to be a collaborative project. Hopefully, The top portion would be a repeating mag fed sling (Pseudo-Semi auto?), and the bottom part would be a mag fed repeater (semi auto?). they would be modular, and be able to fire separately. Also, it would be cool if when connected, they both fired with the same trigger.
If pulled off right, this project could be very innovate, and advance knex considerably. That is, if good range could be achieved. Also, it would be an awesome replica. I'm not sure which part I'll do, but it'd be great if some people wanted to be part of it, and if these people had some good ideas for mechs.
Picture of Help Needed
1-10 of 23Next »
I could help, what do you want making.
rec0n (author)  SLDxRaPiiDZz6 years ago
Are you good at sling mechs?
not really but I could help with some of the SOPMOD kit.
Huh, well KGB will already be on that. Are you any good at true-bolt action mechs?
Oh, ok and not really.
I only see 2 major things to change: the stock is too big, and the front rails or heat guard is too small.
rec0n (author)  shadowninja316 years ago
What dimensions? I modeled the RIS straight off a VFC URX RIS, and the stock is an LE stock at the 5th position.
Okay well from the pictures, it looks too large compared to the airsoft.
The stock? The RIS is a replica of the one on the top M4, and the stock on the middle M4 is at the 3rd position.
Yes the stock. It seems too large.
1-10 of 23Next »
