Help electronics beginer
Hi,
I am trying to learn electronics and have few questions about some confusing stuff:
- If one is measuring current in a circuit, he is supposed to connect the multimeter into the circuit. Ok, how do you measure current in the arbitrary track on the PCB? Are you supposed to cut the track open, just to take one measurement?
- I have bench power supply, on which one can select voltage and current. If I connect toy electro motor it runs nicely. Power supply shows 3V, 0.17 A. But when replace electro motor with 1,800 ohm resistor, no current is drawn. If I insert multimeter between the resistor and terminal, multimeter shows that no current is flowing.
Why there is no current flowing when resistor is connected and there is current when motor is in
regards,
dejan
Awesome Discounts for Pro Members
JUNE 2013 Build Night - 3D Printing with 123D & Tinkercad
Instructables Build Night w/ Bare Conductive @ Noisebridge
Embed a 3D viewer in your Instructable
Maker Faire 2013 Slide Show!
Fried Contest Launches 5/13, HQ Celebrates with Fried Day Friday
MEH! :D A Build Night at Montana Ethical Hackerspace!
Got contest ideas? Want to help HQ staff?
Large Instructables Robot head made out of driftwood, check it out!
Call for pre-made parts!
Visit Our Store »
Go Pro Today »
MEASURING CURRENT: yes, you must OPEN some portion of the circuit to measure current (amperage). HOWEVER i dont recommend someone just learning do this. If you do this WRONG you could damage your multimeter or damage the item you are testing. For example, if the meter probes were improperly connected to GROUND while meter is set for AMPS.... you would damage the circuit under test. so AMPERE readings are not for beginners.
do a lot of VOLTAGE and RESISTANCE testing before you tackle AMPS. You should NOT cut an "arbitrary trace" unless you KNOW what kind of signals
and voltage are on that trace.... could be AC .DC .. could have RF on it, or it
could have combinations of those on it.
CUTTING A TRACE: when working on equipment for repairs... a technician would NOT CUT A TRACE unless no other method could be found. You might be able to LIFT one leg of a component... or measure somewhere else more convenient... also, technicians RARELY do amperage measurements... we do VOLTAGE measurements (with circuit ON) and we do OHMS and DIODE JUNCTION tests (with circuit powered OFF). amperage only rarely. Cutting a trace causes more work to repair, Easier to just remove one wire of the motor, if you want to measure amp draw of the motor. Hope that helps you a little.
They cover a real lot of stuff, are easy to read and even I can understand them.
http://www.allaboutcircuits.com/
There are various methods. But that depends on nature of the signals you want to measure.
If it's DC, you could measure the voltage at the terminals of a resistor on the track you want to know the current. Then, knowing the value of the resistor and the voltage at its terminals, you could calculate the current thanks to the Ohm's law. But this only works if the signal in the track is DC and constant.
Why there is no current flowing when resistor is connected and there is current when motor is in ?
If everything works correctly, there should be a tiny current of 1.7 mA. ( 3/1800 = 1.66 x 10-3)
But maybe you can't see it because your multimeter is not enough sensitive or is set on the wrong decade.
