Help, please: Opening a sealed camera battery
I have several exhausted NiMH camera batteries, for a camera I rarely use anymore. The batteries (or perhaps the charging system) were awful. But I would like to use it as a backup--maybe by replacing the NiMH cells, or inserting smaller Li-ion unit...
Anyone been successful at opening these? I think the seams are welded...
14
comments
Add Comment
sort by:
active |
newest |
oldest
did you try unscrewing that little screw on the top (in the picture). Although that probably wont help..
Oct 20, 2007. 5:52 AMgmoon (author)
says:
I did try that...the end cap (left in photo) unscrews, too. No good.
Oct 19, 2007. 3:08 PMPunkguyta
says:
Well, squeezing a battery in a vice is a good way to lose the hand that is operating the vice. It should be pry-able but if all prevails, dremel+cut off disk.
Oct 19, 2007. 4:13 PMgmoon (author)
says:
The last time I tried it, I didn't have a dremel. I do now, and that's a great idea. I've never heard of NiMH batteries exploding, although I guess they could if you overcharge/pump massive current in to 'em. This one is filled with several AA size tabbed cells. I'll be careful, though.
Oct 19, 2007. 6:53 PMPunkguyta
says:
It'll be fairly easy (at least for me :P) to only cut the plastic, however there is a plastic shell around those AA cells, like a heat shrinked film, then the thick metal casings on the batteries themselves. Don't be worried you couldn't even blow them up if you did get into the battery core. Usually...
Im not quite sure what a vice is. But what i often do to get things like that open. just insert a thin flat-headed screwdriver and turn the screwdriver as if you were screwing something in. Be careful though, it can slip out and slice your hand pretty fast :p.
Oct 19, 2007. 3:31 PMPatrick Pending
says:
I open up old phone batteries for the rechargeables. I generally, cut with a hacksaw then put a flat bladed screwriver in the slot and pry them open. Cheers, Pat. Pending
Oct 19, 2007. 4:09 PMgmoon (author)
says:
Maybe that approach (with Punkguyta's) will work. Just prying sure didn't.
It would be difficult, at best, to remove the batteries without damaging the case they are in.
Oct 19, 2007. 4:07 PMgmoon (author)
says:
Yeah, that's why I didn't proceed any farther without some advice. But I have 4 dead battery units, and don't mind trashing some. I hope to have about a 50% success rate...
Roger Boisjoly dies at 73; engineer tried to halt Challenger launch
Follow up on the Arduino Jam Belgium
I need some help with paper mache angry birds for a party game
A new shirt
Wanna know what I'm doing with the laser cutter?
What would you make with a desktop CNC milling machine
Arduino Jam Belgium
December beard-off!
