loading
Help with MAX232 Serial Converter troubleshooting?
ok..long story short..
built this Instructable: (minimal Arduino on poerfboard,.  w/ blank Atmel)
I put this on a breaboard instead
https://www.instructables.com/id/Perfboard-Hackduino-Arduino-compatible-circuit/
I then installed Arduino IDE, as well as WinAVR/avrdude
I tried to build a parallel programmer:
http://www.arduino.cc/en/Main/ParallelProgrammer
but it didnt work.. (not sure if it because of WinAVR?avrdue setting?  but command line AND flashing bootloader through Arduino IDE did NOT WORK..
AVRDUDE gives this response:
avrdude: can't open device "giveio"
avrdude: failed to open parallel port "lpt1"
pinout for parallel programm was as follows:
PP     ATMEL  (pinout)
1    -  19
2    -  17
11  -  18
16  -  1
18  -  GND on breadboard***
no clue even Ive asked and googled.. couldnt find a 'real' solution to this..
so I looked around..and I found a couple MAX232 chips laying around..figured Id use these to build a Serial Converter using this tut:
http://sodoityourself.com/max232-serial-level-converter/
I this all set-up on my breadboard: (pics to check what Im doing wrong)
*******(the images shows the vRegulator moved over 1 pin..it has been corrected but after pic was taken)
http://dmstudios.net/misc/max232_circuit/top.jpg
http://dmstudios.net/misc/max232_circuit/1.jpg
http://dmstudios.net/misc/max232_circuit/2.jpg
I have checked the vRegulator portion..  I have a cap BEFORE the regulator  *bridging GND & output*
and I use my meter to check that there is, in fact, 5v coming from it..  and there is...
HOWEVER...  the vRegulator gets SUPER HOT, SUPER FAST!...
if I dis-connect the pin 16 form the  chip to the ++ then the vRegulator does NOT get hot...
once I bridge it.. instant HEAT..
so is it something I have done wrong in my diagram?
http://dmstudios.net/misc/max232_circuit/diagram_1.jpg
vRegulator not show in diagram here;;
in this diagram.. as soon as I hook up the V++ to pin16 on the chip.. and the cap..etc  something is wrong??
I 'do' have some FTDI cables coming from China for a few bucks.. but this is ONLY for sketch uploading...correct?
I also have a true Arduino Due coming as well... but hate waiting weeks when I want to play and get started now!
Any help is appreciated..   Im new to all this, so be nice!  LOL
thanks gang!
