Help with Viewfinder Pinout??
I ripped if off an old camcorder in the dump like 2-3 months ago, remembering a few different projects I've seen on here (and other sites) such as:
http://www.instructables.com/id/Super-Nightvision-Headset-Hack/step3/Disassemble-the-Viewfinder/
(sorry the hyperlink part of instructables never works for me)
I know I've seen a project somewhere online too where a guy used one of these TINY crt's for a miniature arcade machine, just to name an example.
I've ran into a bit of a wall here though, it would seem as though everyone else's viewfinders have indivigual wires coming off the board for power and video input. Mine doesn't, it has ONE ribbon connection (although mangled a bit, I still have the ribbon cable that goes with it).
This is a really simple looking circuit board, but as I don't exactly have lab quality tools sitting around, I don't wanna solder wires onto it until I know for sure which is for power, I'd hate to fry it on the first time!
I tried following the traces on the board but I've never been too good at that, is there some way I can probe around with a voltmeter to determine what is for video input and what is power? I've tried googling numbers off the board and tube and that didn't help either. If anyone can help me power this tube, please tell me!!
comments
Add Comment
Photo 1: Overview of my unit
Photo 2: The connector, with its 10 pins array (3, 4, 3) and 3 of the 4 connections needed to power and video the view finder.
What i found out is that you must connect :
the power-in (red cable - 5 volts)
ground (black)
signal (pink) and
orange cable, which i have no idea what is for, but requires the same 5 volts as the red.
OBS:
- the pink (signal) cable is conected to the Y pin of a S-video out, from some dvd player or alikes. The Y-ground pin should also be grounded.
- The whole thing requires 140mA to run. The 7805 i was using to regulate the 5 volts would heat up and stop working after some 5 minutes of continuous work.
Photo 3: The connectors i made out of a very tiny cable-to-board male conector. I just had to crimp some more the contacts, so that they touch the pins.
Photo 4: Detail of previous
Photo 5: Proof that it works. Photos taken with celphone (sorry) and the lens of the viewfinder.
Hope it helps.
The ORANGE must be GROUNDED. (do not connect it to 5V, connect to ground, goddamit)
What i did on mine was determine the pinout, since its conector was a round, 10 pin, panasonic exclusive (i think) one.
After using a voltimeter to define what was each pin, so i didn't have to split the cable, i ripped a tiny molex conector apart, using each crimped contact as a probe, insulated them with heat-shrink and made the conections through a bread board.
Ok, i'll take some photos and be back.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
