Help with an old circuit diagram, please?
Remember my inductor thread?
Well, I'm getting closer to my project. The bulk of the device is to be based around an old transistor radio. I've got hold of one (a Phillips D1018/05, if it helps).
Wonderfully, I opened the radio to find it has the circuit diagram stuck inside the back cover.
Unfortunately, it's only half an inch high, so, I've scanned it.
Now, I have a problem:
The directions I am working with are vague:
Try removing the Ferrite tuning coil and then replacing it with (another detecting component which I have, but if I name it the surprise will be lost) with a 12mH inductor connected in parralel.
Spelling aside, I was happy with this, until I opened the radio and found that the antenna has four wires connected to it.
So, I need a few answers:
  • In the circuit diagram, which part is the ferrite tuning coil / antenna? I think it's part of the bottom-left corner of the diagram, but I need to confirm this.
  • The four wires all disappear through the same hole, but one is stained blue and one red - which ones should I be dealing with?
  • The component I am replacing the coil with is polarity-sensitive. The vendor was very careful to indicate the negative electrode - which way round should I connect it? I think I need to connect the negative of the component towards the bottom lead of the circuit diagram, but I want to make sure before I kill the component.
I know these are potentially-noob questions, but this is my most expensive project so far, and some of the parts required subversion to acquire, so I don't want to mess it up.
(If there's anything I've forgotten to ask / say, please let me know that as well. I'd rather not reveal the nature of the final project; it's not for a contest, but there's nothing like it on the site yet. If useful advice depends on knowing what the component is, then I will reveal it, but I'd prefer not to spoil the big unveiling.)
Picture of Help with an old circuit diagram, please?
1-10 of 16Next »
Normjr7 years ago
Is it possible to get a larger, clearer image of the left (Input) end of the diagram?
Kiteman (author)  Normjr7 years ago
Not really - that's a scan of an original that is only half an inch tall.
I'm assuming the project is long-dead anyhow?
Kiteman (author)  Lithium Rain7 years ago
I prefer "in a long term hiatus".
Hehe.
robomaniac9 years ago
I love reverse engineering!
Here are circuit that look the same, these are radio circuit.
http://people.msoe.edu/~reyer/regency/schematic.jpg
http://www.ibiblio.org/kuphaldt/electricCircuits/Semi/03453.png
You read circuit like you read a book, from left to right.
The antenna is the coil with the 4 wires. The one you have circle in the schematic.
If you look closely. Use in Firefox3 Ctrl and + to zoom.
4 wires and 2 are connected to ground. One is going to the capatic
Do you have to remove the ferrite tuning coil to replace it with your magic component?
You need to place you magic component before the capacitor and then to the transitor. One wire goes there and the other one goes to the ground.
look here
You remove the L1 and forget about L2 and C2. Your component will go to the ground and to C1
You need to turn the PCB around and use the multimeter.
I suggest you start the instructable and add only these pictures and make it collaborated so I could tell you whre to put your prob. You write a gimmick title and upload the picutres and the schematic I gave you. Then we will be able to work together.
I don't read it like that at all. The antenna coil is the two-part inductor (connected to Q1 and C2, with the long line--the common core.) It corresponds to L1 and L2 in the ibiblio schematic, but isn't wired the same.
Kiteman's comment box only encloses half of the antenna coil.
In the ibiblio schematic the split antenna coil may be connected to gnd in two places, but only one lead of the antenna (T2) in Kiteman's schematic is. L2 corresponds to the top winding of T2. For kiteman's, one end is connected to the collector of Q1, and the other to the next inductor in the signal chain.
The placement and operation of L2 (1/2 of T2) is fairly different between the two circuits.
Kiteman (author)  robomaniac9 years ago
Oh, good idea!
Kiteman (author)  Kiteman9 years ago
Done - you're a collaborator now.
I would say that your best bet is to get to the other side of the board with a multi-meter and double check where everything connects. You never know, the text at the bottom of your schematic may be correct "subject to change without notice" !!! Once you have confirmed the circuit diagram and all the main components, you will be in a better position, but I would imagine you will be trying a little trial and error with this one as there are many different methods of implementing the tuner stage. An idea might be to post a question on an amateur radio forum. I have found and looked through the original information you refer to for this project, have you tried contacting the author directly?
1-10 of 16Next »
