3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade skate / mountainboard trucks?
Does anyone have any ideas how I could make something that resembles a skateboard or mountainboard truck at home? I want to build my own motorised mountainboard from various parts on the very cheap, of which none will actually be from a board. The trucks seem like the one thing I might have to buy since I can't think of a way to add turning and carving capability to a homemade board. Any ideas would be most appreciated.
17 comments
Jul 24, 2011. 1:32 PMdmiti says:
What are you goin to do is to look at this picture
http://www.atbshop.co.uk/images/mindless/mindless_longboard_truck_7_detail_i.jpg
As you can see it is all about ANGLES-how much angled is your truck.
In a couple days i'm goin to make this! It will work,trust me...i'm goin to show you results,if i don't forget...
Now,do You have Cinema 4D? You do? Please download this,and see my 3D poject,it's truck,and if you want to make your own,look at the parts of 3D project...
http://www.megaupload.com/?d=WTNTVYHK
Now,see the video:
http://www.megaupload.com/?d=IF8PMBT7
And please see this video:
http://www.youtube.com/watch?v=G_W1G0pcQ18&feature=related on YT
THIS IS NOT ME!
This guy will shiw you patrs of longboard truck,whitch can be used to make MOUNTAINBOARD truck,the same thing,truck,just mountain truck would be much stronger... :)
That's all
Hope i help :)
Sep 17, 2010. 4:12 AMDARK SNIPER says:
i have tried building trucks
but it didn't work
i couldn't go left and right
so if someone tried that and it worked for him
please give us the principle
Feb 16, 2010. 9:34 PMc p skeates says:
it's almost impossible to get any where in australia trying to get a mountain board and even motorize it and so building one is the only option ..the above home made boards look good enough to try and simple .http:sites.google.com/site/skeatesy
Nov 12, 2008. 11:31 PMskunkbait says:
I dunno. If you could fabricate your own that'd be good, but it would take some serious tools/skills. It kinda depends how much "error" you can stand if you go the "trial and error" route. You'll basically be re-inventing a tried and true technology. I'll ponder it a little, but you'd probably do best to just buy a set, or seriously modify a set from an old freestyle board.
Nov 12, 2008. 11:41 PMskunkbait says:
Ok, if you affixed axles with a limited amount of pivot to the end of a fairly flexible leaf spring, then MAYBE. But I'm still thinking you'd be better off to buy them.
May 14, 2009. 9:41 AMjayburd says:
If you'll notice, there is an angle bent into the "gooseneck" that is attached to the board. The angle is where the magic happens. When the board tips, the magic angle actually forces the two wheels on the turning side to get closer together and the wheels opposite further apart. Check out the design process this guy has explained. http://www.benarent.co.uk/portfolio/potential_atb/potential_atb.php
Nov 14, 2008. 2:59 AMskunkbait says:
It's funny. I "invented" the mountain-board back in '87. Everybody thought I was nuts. Now it's a real sport! I don't know when this kind of board was really invented, but maybe if I can find that one old picture of it (and me as a 16 year old) then I can prove it was "my" idea.
May 13, 2009. 8:58 AMfrank01992 says:
you can make trucks like channel trucks just with some steel if u are able to weld. if u want more info and pics let me kno
Mar 24, 2009. 3:13 PMjoshring27 says:
Im just finishing off a mountain board which i built for a school project it turned out okay, i used layers of birch ply(maple is better) and just layered them up with some caskamite to bond them then bunged it in a vac bag on a mould id pre made and left it, worked great, if you can give that a go. In terms of trucks i just bought a second hand board from ebay, i could have made them i think the easiest and most likely to work ones would be a nosno type but for 20 quid for a board and trucks its not really worth making them.
Jan 29, 2009. 2:17 PMMark 42 says:
I Googled "Homemade Mountain board" awhile back, and found a couple of websites.
http://www.sysameri.com/marcelo/mtb/default.htm
http://www.kitelinks.be/kite/Mountainboard_self_made.htm
Jan 29, 2009. 2:22 PMMark 42 says:
Note that the pivot bolt has to be angled so that the axle rotates in the same plane as the ground and in the plane perpendicular to the ground and the denter of the board (it's why the ends of the board are curved upward)
Feb 3, 2009. 12:12 PMMark 42 says:
You're very welcome.
Here's another about making a deck:
http://www.racekites.com/reviews/getReview.asp?reviewID=653
to which I would add that I have what I think is a better forming jig design:
http://www.pbase.com/mark_42/image/94425286
(It's only the concept - might need more forming blocks)
BTW, if anyone runs into a set of plans for a BMX Sidehack... please lemme know!
Jan 29, 2009. 2:19 PMMark 42 says:
This one is really simple, and would be easy to make some minor improvements upon:
http://www.geocities.com/reystos/mountainboard/
Jan 6, 2009. 3:33 AMOmen86 says:
well i desighned 1 a few years ago but it was to complecated for me to build in my garage, also is hard to explain. the basic idea is to turn the lean of the board into a turn of the wheels via a linkage to a fixed point at the center of the board.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
