How To Make A Hole In Airline Tubing?
I'm trying to make a hole about a millimeter in diameter in the side of a piece of standard airline tubing.  I've tried poking a heated needle through the side, but the hole was too small and the heat warped the plastic.  How should I do this without destroying the tubing?
Toga_Dan3 years ago
the tubing is that flex plastic abot 1/4 in in dia?
Toga_Dan3 years ago
one can buy fine drill bits, but if none is on hand, you can make one by grinding a flat on the side of a needle. you basically remove 1/2 the cross section. C|
El Mano (author)  Toga_Dan3 years ago
I'll have to try that and see if it works. Thanks.
El Mano (author)  El Mano3 years ago
A drill bit worked, but not very well. Instead, I took the casing from a disposable ball point pen and drilled a hole in the side of that, which worked much better, and then glued the airline tube to the pen casing.
Toga_Dan3 years ago
your drill chuck may or may not close down to somethin as small as a needle (or a mm) you may wanna find a pin-vice (google it, or try hobby store)) Although these are designed to let u drill with just twisting yer fingers, I have used 1 by chucking the needle in the pin-vice, and the other end of pin-vice in my drill.
Kiteman3 years ago
Have you tried drilling?
I'm pretty sure you can get fine wood-bits down to 1mm.
