How about a teeny tiny power supply??
33
comments
Add Comment
It doesn't quite meet your specs, though:
- Each wire is 4 µm diameter × 200 µm long (~2500 µm3)
- One cubic inch is 15,625×109 µm3
- You could (in principle :-) pack 6.25 billion of these little generators in there.
- In series, that would only provide 50 mA.
For scratch-built, as opposed to module I mentioned elsewhere, there is a reference design for a 5W charger from ON semi that could probably be a bit smaller for the ~2W supply mentioned here and 110Vac-only input, and if you eliminate some of the "niceities." There are some other neat app notes associated with the chip in question, and other vendors have similar chips.
V-infinity 3W encapsulated power supply modules. VSK-S3 series. 1.46*0.91*0.59 (comfortably under 1in3), 3.3 through 24V (at decreasing currents), and about $15 at digikey.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=102-1802-ND
I still want to build the door knob camera =) as heard on M*A*S*H.
I know what you mean about the size and motivation. I've already put this stuff inside those 6-outlet adapter boxes, like the one used for the LED light project on here. THAT was easy. This is a motivational factor. Hey, anyone here work for the CIA?? =)
http://www.hammondmfg.com/229.htm
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
