loading
How can I get a loud alarm?
Ok so I need an alarm for my project, a very loud alarm. . .
And I can't seem to get these dumb buzzer to output a decent sound. I have a lipo checker that uses these type of buzzers
 and they are ear shattering. I tried putting the regular buzzers and the were no where near as loud.
Also if I want to use the tone function on the arduino, how do i make the buzzer louder?
I guess you misunderstood the function of a buzzer.
A buzzer requires a DV input and produces a sound with a fixed frequncy.
A pieco speaker requires an audio or PWM input signal and changes the tone with the frequency.
You can try what you want with a buzzer but it won't change much on the output.
Get a normal piezo speaker or siren and feed it with a proper PWM signal to adjust frequency and loadness - the later depends on the volume level (amplitude).
HavocRC (author)  Downunder35m2 years ago
Hey thanks man. After posting this I read up on active and passive buzzers and figured that out. I'm still having trouble making a loud alarm with the piezo speaker.
To make it really load you need a suitable housing for it - like the piezo sirens for home alarms.
They focus the sound and due to the construction also increase the sound pressure dramatically.
Remove the plastic housing from a piezo siren and you get a load beeper ;)
Depending on your model you can use the feedback contact to optimize the frequency, otherwise stick to the rated power levels and play with the frequencies.
caitlinsdad2 years ago
https://www.instructables.com/id/How-to-make-an-Ard...
I think the pwm coming out of the arduino pin doesn't have enough oomph to drive the piezo loud enough.
HavocRC (author)  caitlinsdad2 years ago
Exactly. That's why I asked "how do I make the buzzer louder?" I know I can output a sine wave/whatever wave from the arduino, but what do I need to make amp the signal?
Read through the ible and image notes. The amp is that mystery chip/component in one of those small alarms.
It seems like all that thing does it produce a wave. . .
If the transformer isn't the amp then. . .
think of that autotransformer thing as a control valve or power transistor for the battery's full current. It opens and closes in sync with the pwm tone signal from the arduino. I guess really not an amp in that sense.
