How can you connect an LCD screen to a YSB001 (MD80 rip-off) camera so you can see what you are filming?
When you film with a good video camera, you can usually see what you are filming by looking at the LCD / viewfinder...
but I have bought one of those very cool, tiny cameras that cost about £10, can be bought on eBay and which come from Hong Kong
But in return for being tiny, it does not have any kind of viewfinder.
I bought mine to experiment with fixing it to my hang glider/microlight to film flights. I figure I can, by trial and error, work out what the actual field of view/ frame is
but I'd much prefer to be able to set up my camera with a monitor of some kind (perhaps using my mobile phone camera?)
Better still, I would like to be able to monitor the camera all through the flight (perhaps be able to move the mount remotely?)
Is there a simple method for achieving this or do I need to do electronics?
Picture of How can you connect an LCD screen to a YSB001 (MD80 rip-off) camera so you can see what you are filming?
lemonie7 years ago
You need electronics. And you're probably best buying one rather than trying to adapt what you've got.
L
Tinworm (author)  lemonie7 years ago
I hear you regarding not adapting the current camera, so what do I need to do, electronics-wise?
lemonie Tinworm7 years ago
If you want a view-finder, you need to get a camera with one. You could think about getting a view-finder from somewhere, but the expense and hassle of adapting isn't going to be any less.
I would have suggested that you make a wire-frame view-finder through trial & error, but you'd like to move the camera, which would be why you want the viewfinder I guess.
I'm a bit stuck for something that isn't complicated or expensive or large. Let's hope someone else can think of something better, or I get some new idea.
OK - how about mounting it on your head? If you do it right it'll film what you're looking at.
L
that is one of the options....and I have been working out the field of view that way (with a tape measure and marks on the wall)...and I guessa  similar method will work with my plane's wing etc....I just hoped that a means of connecting an lcd would made it easier.
I did wonder, for instance, whether it would be possible to use the camera screen on my mobile phone linked via a cable to the camera, perhaps?
Your phone might pick up a web-feed? - if you could make the video camera a web-cam, but you don't have to think too long about that to see what's involved. Phones aren't designed to act as displays for external video feeds, but can you add a large memory-card to the phone and use that instead?
Think about it again - if the camera is on your helmet and it sees what you see, you've got the viewfinder and movement in your own body.
L
will look into webfeeds
but from your various projects, it is clear you know your stuff, and if you seem sceptical, maybe there is good reason.
Yes, I am going for a head mount (but still wanted a wing mount and another on the fuselage)
thanks anyway
Post what you do with this, we'd like to see how this problem is solved.
(Yes I do look at things in "different" ways, but I like to try things I think will work. The ideal set-up would require quite a bit of equipment / or expense I think.)
Best wishes for it
L
ok, check this first test out. It is a line of sight option, mounting the cam on the side of my flying helmet. At the bottom of this link is a short test film
(I may need to put markings on the mount and even a scribed viewfinder on the visor to show the actual camera angle and its limits
That's very good, please package it into an Instructable, use the image with the camera as #1 and embed the video.
L
Thanks for the encouragement, lemonie, I have done it, I have posted an instructable! It is my first one ever!
