How to Identify or Measure Inductance?
I am gathering the parts for an ible, but I am short one part: a 12mH inductor.
I can spot some inductors in electronic garbage - the wire coiled around a ferrite loop - but there are also solid state inductors. Plus, the inductors are not usually labelled with their values.
How can I measure the inductance of an inductor with a volt-meter and an ammeter, but without access to a sine-wave generator?
Is there some simple trick that would get me "close enough" to the true value? What would be really useful (but probably doesn't exist) is a chart or formula where you plug in the size of the core and the number of turns around it and out pops the inductance value.
1-10 of 21Next »
gmoon9 years ago
I've bookmarked a couple links for this myself; though I have yet to try it.
http://engr.nmsu.edu/~etti/fall96/electronics/induct/induct.html
Owens bridge inductance meter
The second link looks like the business....but it's a bit much if you need to measure just one inductor.
I've used the fomula in the NMSU.edu website with sucess. The resultant values will vary a little based on the frequncy used, but that's the nature of inductors anyhow. I've also noticed that no one has mentioned using an LCR meter here. I found one on AMAZON for less than $30 dollars that measures inductors, capacitors and resistors (hence the LCRname) and does so with some accuracy. It's on my wish list at Amazon..
gmoon gmoon9 years ago
Oh, and if you don't have a signal generator, use a small step-down transformer, 6V or something. The frequency of the mains is a little low, but should get you in the ballpark... (50hz for euro?)
NachoMahma9 years ago
Kiteman (author)  NachoMahma9 years ago
I tried that, but I don't have a signal generator.
I remember doing this in the past but have since lost the "configuration" I had (as well as the resistance decade box I made back then), just using a step down transformer and a VOM (plus the decade box of course)
I see that you've gotten sufficient links from others to solve your immediate problem, but no one mentioned the underlying issue.
You can't measure inductance with DC: you need a varying current in order to invoke Lenz's law and measure the voltage drop: deltaV = -L dI/dt. You might be able to do it using your 50 Hz AC straight from the wall, assuming it's stable.
westfw9 years ago
12mH is a pretty huge inductor, assuming that a "milli" m and not a mis-type "micro" u. Counting the turns/etc may not be useful because one of the factors in the equation is the magnetic permeability of the core material, and unless you have an air-core inductor, the core material is just as unknown as the inductance itself, and can vary over 100x even for different types of identical-looking ferrite.
Kiteman (author)  westfw9 years ago
I checked the instructions, and it's 12mH, and the part number matches. I'm waiting for emails from companies that turn out to be all over Europe to see if they can get me one. It's a problem because the manufacturer is American, and the (environmental) rules changed recently? Anyhoo, we'll see. I'm reluctant to go into details because the project so far does not exist on the site in any form, and I'd kind of like to be the first.
Coilcraft offers several and they are RoHS compliant, and if you ask nice they will give you a free sample...
1-10 of 21Next »
