How to Make Lanyards yourself?
Creative types may be curious to learn how to make rubber bracelets
. If you are able to follow simple directions you will be able to produce your very own ones for personal use or to give as a gift. Whether for yourself or a as a gift, it will be a great way to secure your keys, cell phone, badge, or whistle.
In learning how to make lanyards it is important to choose the right material. A popular making material is a thin, elastic, and flexible plastic lace. It is readily available at most craft stores and referred to as craft lace, , gimp, or boondoggle.
There are many different stitches that can be used to make or braid . Many braiding techniques are complex and time consuming. One of the simpler braids is referred to as a crown (or round) knot. One must utilize patience and follow directions carefully in learning how to make rubber wristbands
. The basic crown knot is as follows:
1. Take two strands of craft lace, fold them in half together (length will depend on the type of lanyard) and tie a knot toward the top to hold them securely together.You now have four strands secured at the top.
2. Spread the four strings apart, separately, pointing in each cardinal direction of a compass. Hold the left string with one finger (close to the knot). At the same time, pull the left string over the top string.
3. Cross the top string over the right string. At this point the top string is covering both the left string and the right string. Now cross the right string over the bottom string. Finally, cross the bottom string over the left string and tuck it under the looped top string.
Pull each end of the four strings extremely tight to make the first knot. Continue crossing the strings in the same manner until the desired length is reached. The knots will produce a rounded href="http://Www.ybuw.com" target="_blank">silicone bracelets</a>
4.
Do you think it a good way to make a gift to convey your sincere feelings?So, let’s do it now!
