How to Take Down a Traverse Decorative Rod
Hello Friends,
Decorative traverse rods are one way to accentuate your windows with drapery. Traverse rods enable you to open and close the drapes with a pull cord. Sometimes one or more of the rings breaks requiring replacement. Unfortunately replacing rings requires removing the traverse rod from the window. Taking down a traverse decorative rod enables you to separate the rod and remove the faulty rings. Unlike standard rods, the traverse rod fits inside a channel clip across the top of the mounting brackets.
Unhook the drapes from the traverse rod master carrier. The drapes hang on metal hooks that lift out of holes in the traverse rod.
Hold one end of the traverse rod with one hand and turn the decorative end cap counterclockwise with your free hand. Remove the end caps on both ends in this manner.
Find the screw on the retaining clips securing the rod to the mounting clips. There is a mounting clip on each end and one in the center.
Remove the screws with a Phillips-head screwdriver. Grasp the center of the rod and lift straight up to remove it from the brackets. Pull the rod away from the wall.
Thanks and Regards,
Baron Davis
Kiteman4 years ago
You ought to post this as an instructable, with step-by-step photos.
