How to do a hollywood style explosion
Hey, dose anyone know how to do a Hollywood style explosion. Sort of like the ones in Monty Python and the Holy Grail where there is a large fireball. I have heard of taking a plastic soda bottles and filling them with gas, but I was not very fond of this idea.
1-10 of 16Next »
ishakook204 years ago
They forward style exploide again and again ,
TimmyMiller5 years ago
does anyone know how to make a really good underwater explosion? i plan on making a underwater mine, but i want to take it to the next level? help
Depending on what types of explosives you have access to I can give you a few good ideas.
Grim1234 years ago
Primary explosive, gunpowder works but det. Chord is better, wrapped around plastic jugs full of gasoline. If you're using a solid mass of explosives instead of one that can be wrapped around the jugs, place it in the center of each jug. This will give a massive fireball and fairly good pressure wave.
zombiefire7 years ago
goto this link http://www.metacafe.com/watch/901530/make_huge_fireballs_from_materials_at_home/
CameronSS9 years ago
I know that to create the "wall of fire'' type explosions you see at airshows, they use dynamite and gasoline--the dynamite creates the heavy "thud" sound, and the gasoline makes the giant fireball. Just be careful, gasoline vapor is more flammable than you might think.
No they dont... They use an acetylene mortar and a pipe pressurized with a JP fuel and Gasoline mix. The pressure is released in time with the acetylene mortar and Boom....simulated Napalm strike...this was done in a massive scale for the movie Apocalypse Now.
Flammable? More like explosive. I have seen hot embers put out by the liquid portion of gasoline, but I have also seen the fumes ignited by a static spark off a carpet blow a person over onto their back. Gasoline is only safe as in "internal" fuel in an internal combustion engine. And outside it can be very unpredictable. The breeze will carry fumes in an unexpected direction; you light a match or lighter and Fa-rooom; you have no skin. Too many people are injured each year starting garbage burning fires using this fuel.
Kiteman9 years ago
For a nice big woosh fireball, I'd fill a plastic bag or large balloon with flammable gas (butane from a blowtorch, propane from a BBQ tank or methane from the mains), and tape a length of nichrome wire to the outside - connect the nichrome to a large battery, it gets hot and woomp!
For a bit extra colour in the flame, try a small splash of petrol into the bag first.
If the wire just melts the bag or bursts the balloon without lighting the gas, try again with one of those "electric matches" that they use to ignite model rocket motors.
Sedgewick17 (author)  Kiteman9 years ago
I have done experiments with flour before, and I found it kind of unpredictable, but I can try Cremer. A balloon filled with propane sound like it would work I will give it a try also.
1-10 of 16Next »
