3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a "Private" instructable without going pro!
Hey just wanted to share how to make a "Private" instructable without going pro! It was too easy to make a instructable so I'm making this forum topic, thanks for reading..... STEP 1: Make your instructable..... STEP 2: Do not publish your instructable..... STEP 3: Just view your instructable (Not published) and get the URL from the address bar of your browser and then you can share it with anyone you like! Hope you enjoyed this! Your Digitally, Amakerguy
21 comments
Jul 21, 2009. 2:50 PMewilhelm says:
You can change the URL of a private Instructable, and if there's enough interest, we'll build some sort of password protected private versions.
May 12, 2012. 9:03 AMemilyvanleemput says:
how can you make an unpublished instructable private?????
May 12, 2012. 9:26 AMcanucksgirl says:
Open your instructable in "edit mode". When you're ready to publish it, click on the "More" option (found to the right of the "edit", "publish" and "share" tabs). You'll see a list of options that open under "More". Select "Private" from the list, and the page will proceed to the publishing step as a Private Instructable. It indicates that you will receive a "special URL" for sharing it (if you choose to). At this point, all you need to do is click the orange "Make my Instructable private!" button.
Let me know if you need any clarification, or have any further questions. ;)
May 12, 2012. 11:00 AMemilyvanleemput says:
thanks for your help
Jul 21, 2009. 3:54 PMlemonie says:
Second thought: would the coding be easier if "private to members within this group" was the way it worked? L
Jul 21, 2009. 3:53 PMlemonie says:
Hi, I tested this and found out. However, for no particular reason I had the expectation that one might be able to list other users as having "permission" like on network drives. It would get tedious for a lot of users, but for a handful might be a bit more useful if the code would allow (do not know) L
Jul 20, 2009. 12:20 PMlemonie says:
Yes we know about this. However, it's not the same as private (according to Eric) because anyone who knows / finds the URL can view it. L
Jul 20, 2009. 10:50 PMWeissensteinburg says:
Isn't that how pro works?
Jul 21, 2009. 1:02 PMlemonie says:
No it's a new feature that's different. You could try it? L
Jul 21, 2009. 1:07 PMWeissensteinburg says:
I know it's different, but the URL part. I thought private just gave you a special URL to give out to friends.
Jul 21, 2009. 1:46 PMlemonie says:
It does, try this:
http://www.instructables.com/id/ovH1z9z33l1RuZmU4V8Ou2PIpsBaGb/
L
(but the main difference seems to be that you can keep changing it)
Jul 21, 2009. 1:11 PMlemonie says:
OK look at this:
http://www.instructables.com/id/jBRO8ysM62jiOVkO333gmNK1MQnqyh/
Let me know if you can see it
L
Jul 22, 2009. 12:39 PMjedi pen-gui-n says:
no.
Jul 22, 2009. 3:24 PMlemonie says:
Exactly, I changed it. The one above should work though. L
Jul 21, 2009. 1:15 AMlemonie says:
My understanding of the Private function is that it's somehow more secure / private. But I've never been inclined to try it, yet. L
Jul 21, 2009. 2:23 PMKiteman says:
As I understand it, private ibles don't show up on searches, or when you look at an individual's orangeboard. It is possible to search an individual's unpublished projects by manually editing the url, but the same trick cannot access private ibles.
Jul 21, 2009. 2:40 PMlemonie says:
Can you find my unpublished projects? (and how?) L
Jul 21, 2009. 2:50 PMKiteman says:
Eric showed me how some time ago (naturally, I can't find it now), and I wouldn't spread it around if I could remember it anyway. It involved editing the url.
Jul 21, 2009. 11:30 AMDJ Radio says:
congratz, you beat the system! get a cookie.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
