How to read uart data and write to i2c device.
// Port for the I2C
#define I2C_DDR DDRD
#define I2C_PIN PIND
#define I2C_PORT PORTD
// Pins to be used in the bit banging
#define I2C_CLK 0
#define I2C_DAT 1
#define I2C_DATA_HI()\
I2C_DDR &= ~ (1 << I2C_DAT);\
I2C_PORT |= (1 << I2C_DAT);
#define I2C_DATA_LO()\
I2C_DDR |= (1 << I2C_DAT);\
I2C_PORT &= ~ (1 << I2C_DAT);
#define I2C_CLOCK_HI()\
I2C_DDR &= ~ (1 << I2C_CLK);\
I2C_PORT |= (1 << I2C_CLK);
#define I2C_CLOCK_LO()\
I2C_DDR |= (1 << I2C_CLK);\
I2C_PORT &= ~ (1 << I2C_CLK);
void I2C_WriteBit(unsigned char c)
    if (c > 0)
        I2C_DATA_HI();
    else
        I2C_DATA_LO();
    I2C_CLOCK_HI();
    delay(1);
    I2C_CLOCK_LO();
    delay(1);
    if (c > 0)
        I2C_DATA_LO();
    delay(1);
unsigned char I2C_ReadBit()
    I2C_DATA_HI();
    I2C_CLOCK_HI();
    delay(1);
    unsigned char c = I2C_PIN;
    I2C_CLOCK_LO();
    delay(1);
    return (c >> I2C_DAT) & 1;
// Inits bitbanging port, must be called before using the functions below
void I2C_Init()
    I2C_PORT &= ~ ((1 << I2C_DAT) | (1 << I2C_CLK));
    I2C_CLOCK_HI();
    I2C_DATA_HI();
    delay(1);
// Send a START Condition
void I2C_Start()
    // set both to high at the same time
    I2C_DDR &= ~ ((1 << I2C_DAT) | (1 << I2C_CLK));
    delay(1);
    I2C_DATA_LO();
    delay(1);
    I2C_CLOCK_LO();
    delay(1);
// Send a STOP Condition
void I2C_Stop()
    I2C_CLOCK_HI();
    delay(1);
    I2C_DATA_HI();
    delay(1);
// write a byte to the I2C slave device
unsigned char I2C_Write(unsigned char c)
    for (char i = 0; i < 8; i++)
        I2C_WriteBit(c & 128);
        c <<= 1;
    //return I2C_ReadBit();
    return 0;
// read a byte from the I2C slave device
unsigned char I2C_Read(unsigned char ack)
    unsigned char res = 0;
        res <<= 1;
        res |= I2C_ReadBit();
    if (ack > 0)
        I2C_WriteBit(0);
    else
        I2C_WriteBit(1);
    delay(1);
    return res;
Posting virtually uncommented code, with a single line question isn't conducive to getting any help.
1.) What are you trying to do ?
2.) What processor ?
3.) What development environment ?
Ditto.
Blixxer (author)  steveastrouk2 years ago
Hi Steveastrouk,
I'm trying to read data from serial port uart using at90s2313 and write to EEPROM chip 24c16 using i2c protocol
Which compiler ?
Don't use I2C, find something with SPI instead.
I think this discussion on another forum might give some infos:
http://www.keil.com/forum/2436/
Kiteman2 years ago
Huh? Are you asking or telling?
Blixxer (author)  Kiteman2 years ago
I need help on this.
Thanks.
