3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Human Detector
I'm trying to come up with a small, cheap, simple circuit that will detect a human. I plan to use a grid of luxeon rebel OLEDs and whatever detector I come up with embedded in my ceiling to light up only when you are under them. I've looked into passive infrared, but it's fairly expensive for the components I could find. Any leads for circuits, ideas, or parts? I'd use parts from cheap security lights, but they tend to be around $10 each and I would probably need around12-18 ... kinda painful on the pocketbook. Thanks in advance for any help!
13 comments
Jan 30, 2008. 7:21 AMgmoon says:
At .99, you could probably reverse engineer the detector (based on other PIR schematics), even if you bricked a couple.
One point--you could reduce the number of sensors by widen the detection area of each one. Detection response could be based on whether you're triggering 1,2, 3 or 4 sensors simultaneously.
More of an interconnected mesh, than individual autonomous sensors. More logic complexity and wiring, but probably cheaper...
Jan 30, 2008. 10:39 AMgmoon says:
Yeah. I'd tend to use a micro. But I bet you could do it with discrete gate logic, too. The devil would be in the details ;-). Sure would make an interesting exercise in logic, though...
Jan 30, 2008. 7:24 AMthejrb says:
You would probably want something that would beep or flash or something when it senses heat at the body temp. No clue how you would do it but a start.
Jan 30, 2008. 6:06 AMgmoon says:
You don't want PIR, but I've seen the detectors and boards sold very cheaply, if you look around-- here's an example...
You probably already saw the PIR detectors for robotics 'ible posted here just days ago....
Jan 30, 2008. 6:07 AMgmoon says:
Elec Goldmine also has the detectors alone for 0.99 ....
Jan 30, 2008. 3:47 AMschorhr says:
A couple of IR-Beams across the hallway in shoulder-height might do it. If a beam is blocked, someone must be present. Dont use the sensors as coathangers though.
Jan 30, 2008. 1:25 AMPatrik says:
Do you have any pets - or a roomba? If not, that simplifies things significantly!
Jan 29, 2008. 9:43 PMGoodhart says:
To make the detection you have to detect what is unique about a human (as opposed to say, a bear, dog, deer, automobile, etc). There is size (but then we have bear and a few simians) warmth to separate out the non-living....what will be the method of determination / seperation?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
