Hydrogen for renewable energy storage- total system efficiency?
Say I have a wind turbine or solar panel or whatever, that produces 1000 Wh per day. If I use that electricity to electrolyse water, store the generated hydrogen at roughly atmospheric pressure in an upside-down water butt or a big gas-tight bag in my shed (don't worry, I'm not going to actually do this) and then feed it into a generator converted to run on H2, what percentage of that initial energy input would I get back out? 20%? 5%? 1%?
The follow-up questions to this are
a) How does that compare against a battery bank? What about a similar DIY-style pumped water storage system?
b) What one component of the system should be improved to raise the overall system efficiency? Electrolyser, storage, generator?
c) Are there any other DIY-friendly methods for storing intermittently generated electricity that I'm not thinking of?
And, I suppose,
d) Does doing this and providing 5-10x your overall power requirements in wind turbines work out cheaper than spending thousands on batteries?
11
comments
Add Comment
So, you're looking at putting 1000Wh in this idea and getting 100-150Wh out.
Still, 10-15% efficiency is actually better than I'd thought.
Also, I suspect that supercapacitors may be more efficient than batteries, although they would cost even more.
@PKM - did you see the latest "James May's Toy Stories"? The one where they make another attempt at the ten-mile train set?
They had an extra challenge, with "alternative power" trains as well, and one was fuel cells fuelled by hydrogen generated the day before with a solar cell.
My other question still stands- is there any other way of storing and retrieving electricity that's open to hacking? Deep down I know batteries are probably the most practical right now, but they're just... boring. Generating a shedful of explosive gas is so much more exciting!
Unless, of course, you meant that you can't get more than 100% efficiency because that's a ridiculous idea that violates fundamental laws of physics, in which case the appropriate response is probably "duh" :)
Well, the title DID say "total system efficiency?" :P (I was being more smart-aleck than anything else)
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
