loading
I have a question about Arduino Uno R3 stacking shields for a project
i just started on a Arduino UNO R3 project, Its basically a vehicle (a tank) with 2 separate DC Motors, that controls its movement. Another part of the tank would be a Camera dock, which would be made up of 2 Servo motors which basically moves the camera Up, Down, Left, Right.
To control the Vehicle i would use an Xbox 360 wireless controller. So far the only thing i figured out is that i would require two shields, One would be the Motor shield (Controls Both dc gears and Servos: http://www.ebay.com.au/itm/Motor-Drive-Shield-Expansion-Board-L293D-For-Arduino-Duemilanove-Mega-UNO-/280844181299?pt=LH_DefaultDomain_15&hash=item41639e1f33),
The other shield would be the USB Host shield (http://www.ebay.com.au/itm/USB-Host-Shield-2-0-For-Arduino-/330832197023?pt=LH_DefaultDomain_15&hash=item4d0722b59f - this would be used for the 360 wireless receiver) .
The thing is is it possible to combine all three, if not what would be alternative solutions?, thank you
Tomdf4 years ago
I'd wager that there is an Xbox controller library for Arduino out there somewhere
caitlinsdad4 years ago
A couple of things to consider but I will throw it out there... I think your wireless Xbox controller needs to communicate with an Xbox that has the receiver and smarts to interpret the signal. If you just want to use the controller as a signal transmitter, then the arduino needs to be able to receive the signal and interpret it. I don't know what you were going to plug into the USB host since just hooking up a wireless adapter/router might not do anything. Take a look at this http://www.sparkfun.com/tutorials/348 Also, using both shields, I don't think they are really intended to be stacked on top of each other, you need to consider the pins(input/output) that they use on the arduino and that the pins can be shared.  The xbee shields are for wireless communication but I have not used them so hopefully someone knowledgeable will comment.  Good luck.
